Habe getrennte Wlans 2,4 und 5 GHz
mfg
mfg
hab nen zweiten Roborock geholt und seit dem ich den in Roborock App hinzugefügt habe, klappt die verbindung nicht mehr.
Alt Saugi:
Name Mitsos : Roborock S5 Max
Neu Saugi:
Name Kitsos: Roborck Qrevo Pro
Hat einer eine idee?
Model=unknown] getSerialNumber | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Mitso] [Model=unknown] getFirmware | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Mitso] [Model=unknown] getCleaning | Failed getting the cleaning status. Error: Not connected yet
at DeviceManager.get device [as device] (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/device_manager.ts:86:13)
at DeviceManager.property (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/device_manager.ts:92:17)
at DeviceManager.get state [as state] (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/device_manager.ts:73:17)
at DeviceManager.get isCleaning [as isCleaning] (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/device_manager.ts:77:43)
at MainService.getCleaning (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/main_service.ts:115:45)
at On.getHandler (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/main_service.ts:45:25)
at On.<anonymous> (/usr/lib/node_modules/homebridge/node_modules/hap-nodejs/src/lib/Characteristic.ts:2404:32)
at step (/usr/lib/node_modules/homebridge/node_modules/tslib/tslib.js:196:27)
at Object.next (/usr/lib/node_modules/homebridge/node_modules/tslib/tslib.js:177:57)
at /usr/lib/node_modules/homebridge/node_modules/tslib/tslib.js:170:75
[28.11.2024, 20:17:11] [Mitso] [Model=unknown] getSpeed | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getSerialNumber | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] INF ensureDevice | unknown model | The socket was destroyed or not initialised, initialising the device
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getFirmware | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getCleaning | Failed getting the cleaning status. Error: Not connected yet
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getSpeed | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getWaterSpeed | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getDustCollectionState | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:11] [hue] Stella: set homekit supported transition configuration to {"configuration":[{"iid":11,"characteristic":1},{"iid":13,"characteristic":2}]}
[28.11.2024, 20:17:11] [hue] Hari: set homekit supported transition configuration to {"configuration":[{"iid":11,"characteristic":1},{"iid":13,"characteristic":2}]}
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'On': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Status Low Battery': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Battery Level': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Charging State': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Occupancy Detected': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Filter Change Indication': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Filter Life Level': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] Device "lumi.gateway.aqhm01" is not registered as a vacuum cleaner! If you think it should be, please open an issue at https://github.com/homebridge-xiaomi-roborock-vacuum/homebridge-xiaomi-roborock-vacuum/issues/new and provide this line.
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getSerialNumber | Failed getting the serial number. Error: Not connected yet
at ProductInfo.getSerialNumber (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/product_info.ts:83:53)
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getFirmware | Failed getting the firmware version. Error: Not connected yet
at ProductInfo.getFirmware (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/product_info.ts:67:49)
[28.11.2024, 20:17:11] [Kitsos] [Model=unknown] getDustCollectionState | Failed getting the cleaning status. Error: Not connected yet
at DustCollection.get isDustCollecting [as isDustCollecting] (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/dust_collection.ts:30:31)
at DustCollection.getDustCollectionState (/usr/lib/node_modules/homebridge-xiaomi-roborock-vacuum/src/services/dust_collection.ts:37:37)
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:11] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Rotation Speed': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:13] [Mitso] [Model=unknown] ERR connect | miio.device, next try in 2 minutes | Error: Could not connect to device, handshake timeout
[28.11.2024, 20:17:13] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Serial Number': Unhandled error thrown inside read handler for characteristic: Could not connect to device, handshake timeout. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:13] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Could not connect to device, handshake timeout. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:13] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Rotation Speed': Unhandled error thrown inside read handler for characteristic: Could not connect to device, handshake timeout. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] getSerialNumber | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] INF ensureDevice | unknown model | The socket was destroyed or not initialised, initialising the device
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] getFirmware | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] Device "lumi.gateway.aqhm01" is not registered as a vacuum cleaner! If you think it should be, please open an issue at https://github.com/homebridge-xiaomi-roborock-vacuum/homebridge-xiaomi-roborock-vacuum/issues/new and provide this line.
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] getSerialNumber | Failed getting the serial number. Error: Not connected yet
[28.11.2024, 20:17:16] [Kitsos] [Model=unknown] getFirmware | Failed getting the firmware version. Error: Not connected yet
[28.11.2024, 20:17:16] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:17] [Kitsos] [Model=unknown] getFirmware | Failed getting the firmware version. Error: Not connected yet
[28.11.2024, 20:17:17] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:18] [Mitso] [Model=unknown] getFirmware | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:20] [Mitso] [Model=unknown] ERR connect | miio.device, next try in 2 minutes | Error: Could not connect to device, handshake timeout
[28.11.2024, 20:17:20] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Could not connect to device, handshake timeout. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] getSerialNumber | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] INF ensureDevice | unknown model | The socket was destroyed or not initialised, initialising the device
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] getFirmware | No vacuum cleaner is discovered yet.
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] Device "lumi.gateway.aqhm01" is not registered as a vacuum cleaner! If you think it should be, please open an issue at https://github.com/homebridge-xiaomi-roborock-vacuum/homebridge-xiaomi-roborock-vacuum/issues/new and provide this line.
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] getSerialNumber | Failed getting the serial number. Error: Not connected yet
[28.11.2024, 20:17:20] [Kitsos] [Model=unknown] getFirmware | Failed getting the firmware version. Error: Not connected yet
[28.11.2024, 20:17:20] [homebridge-xiaomi-roborock-vacuum] This plugin threw an error from the characteristic 'Firmware Revision': Unhandled error thrown inside read handler for characteristic: Not connected yet. See https://homebridge.io/w/JtMGR for more info.
[28.11.2024, 20:19:22] [Mitso] [Model=unknown] ERR connect | miio.device, next try in 2 minutes | Error: Could not connect to device, handshake timeout
[28.11.2024, 20:21:24] [Mitso] [Model=unknown] ERR connect | miio.device, next try in 2 minutes | Error: Could not connect to device, handshake timeout
[28.11.2024, 20:23:26] [Mitso] [Model=unknown] ERR connect | miio.device, next try in 2 minutes | Error: Could not connect to device, handshake timeout
Ja ist wie gesagt Ferienwohnung.
Ich teste es mal. Habe den conbee 3 geholt im Amazon Prime day für 34€.
Ich weiß ja nicht wo die Reise am Ende hin geht.
Ich werde mal Berichte 🫡
Sorry für die Unannehmlichkeiten …
Ich muss es mal ergänzen. Es geht um die 2te Wohnung von mir.
Wollte das nicht so direkt erzählen ![]()
Ja ich bin 3-4 mal im Jahr dort und könnte jederzeit per VPN auf dem Raspberry drauf... ![]()
Die Wohnung hat gar nichts an Smart home und möchte meine ausrangierte klamotten dort verbauen, daher auch die frage gewesen wegen Conbee stick oder Hue Bridge
mfg
Ich hab ein RPi3b noch. Habe dort schon Homebridge installiert ... Läuft bisher gut ...
mfg
Ja gut, dann hole ich mal den Conbee 3 Stick. Ich selber zu Hause habe bzw nutze Hue Bridge mitz dem hue plugin ...
ich bau gerade für ein kollegen ein Haus um und wollten alles mit zigbee realisieren.
Nimmt man wenn man komplett neu anfängt einen Conbee Stick oder Hue/Dirigera/usw Bridge?
mfg
Also ich habe auch die Eufy 2c Pro und habe dort ein 6 oder 5 Watt Panel dran gemacht und es lief bei mir im Winter durch. Denke wenn der Akku der Kamera einmal geladen ist, wird man ohne Probleme über den Winter kommen oder einfach das Panel nehmen mir integriertem Akku von Sequoia ![]()
Sequoia kannst du mir das Panel schicken was du hast?
mfg
Oder man nimmt einen Wemos d1 Mini mit WLED und kann dann alles anschließen was will und meine dass es eine HK oder per Homebridge integrieren lässt...
mfg
hast du mal rebuild ?
Scheint das Problem am Homematic plugin zu liegen
Habe ich probiert, aber klappt immer noch nicht bei mir. Irgendwie stürzt mein Pi die ganze zeit seit dem ab ![]()
EDIT: Nach mehrmals neu start läft Homebridge wieder. Bekomme aber das in den logs...
[24.10.2023, 18:25:39] [Homebridge UI] Error: Cannot find module '../build/Release/pty.node'
Require stack:
- /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js
- /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/index.js
- /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js
- /usr/lib/node_modules/homebridge-config-ui-x/dist/bin/hb-service.js
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Node.js v18.17.1
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Failed to load node-pty module
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] This could be because the installation of this plugin did not complete successfully or you may have recently upgraded Node.js to a new major version.
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Follow the steps below to resolve this issue.
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Trying to rebuild automatically...
[24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Path: /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch
[24.10.2023, 18:26:14] [Homebridge UI] [node-pty] Failed to rebuild npm modules automatically. Manual operation is now required.
[24.10.2023, 18:26:14] [Homebridge UI] [node-pty] From the terminal run this command to rebuild npm modules:
[24.10.2023, 18:26:14] [Homebridge UI] sudo hb-service rebuild
[24.10.2023, 18:26:14] [HB Supervisor] ERROR: The user interface threw an unhandled error
Error: Node.js global modules rebuild required. See log errors above.
at main (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:29754:19)
at 1808 (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:29806:1)
at __webpack_require__ (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30138:42)
at /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30166:1
at /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30272:3
at Object.<anonymous> (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30277:12)
at Module._compile (node:internal/modules/cjs/loader:1256:14)
at Module._extensions..js (node:internal/modules/cjs/loader:1310:10)
at Module.load (node:internal/modules/cjs/loader:1119:32)
at Module._load (node:internal/modules/cjs/loader:960:12)
Also bei mir geht gar nichts mehr...
Ich versuche das gerade mit dem rebuild ![]()
Werde berichten...
gibt es irgendwie eine möglichkeit in den LOgs zu sehen wieso weshalb der Raspberry abstürzt?
Wenn er abstürzt ist er nicht mehr im LAN erreichbar.
Es läuft nur Homebridge und EVCC drauf... Laut Homebridge 23:27 der letzte befehl, danach war sense ... ![]()
mfg
Ich hab genau das selbe Problem ![]()
Mit freundlichen Grüßen
Ja hatte ich gestern auch gefunden per zufall...
Alles eingestellt und bekomme keine Benachrichtigung mehr...
mfg
13.10.2023, 20:53:12] [FritzPlatform] Error: Unclosed root tag
Line: 291
Column: 0
Char:
at error (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/sax/lib/sax.js:651:10)
at strictFail (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/sax/lib/sax.js:677:7)
at end (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/sax/lib/sax.js:658:47)
at SAXParser.write (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/sax/lib/sax.js:975:14)
at SAXParser.close (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/sax/lib/sax.js:157:38)
at Parser.exports.Parser.Parser.parseString (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/xml2js/lib/parser.js:323:42)
at Parser.parseString (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/xml2js/lib/parser.js:5:59)
at /usr/lib/node_modules/homebridge-fritz-platform/node_modules/xml2js/lib/parser.js:338:24
at new Promise (<anonymous>)
at Parser.exports.Parser.Parser.parseStringPromise (/usr/lib/node_modules/homebridge-fritz-platform/node_modules/xml2js/lib/parser.js:336:14)
Ich hab jetzt auch dieses Problem. Habe gerade die aktuelle Labor auf meiner 5590 drauf gemacht... ![]()
EDIT: Hab die Error Logs, deaktiviert am Plugin. Jetzt kommt die Meldung nicht mehr ![]()
weiß einer wie ich das einstellen kann wenn ich den Geschirrspöler öffne oder schließe, bekomme ich jedesmal von Homekit eine nachricht dementsprechend. Das kann am Tag schon mehrmals sein und meine Famile dreht schon durch.
Ich bekomme aber diese Nachrichten nicht, alle anderen schon im Haushalt/Home verbunden...
mfg
Hallo leute,
hab seit heute folgenden Fehler:
Finde im netz nichts dazu O_o ?!
mfg
Hab es geschafft MM und Homebridge auf einem Pi laufen zu lassen.
Jetzt hab ich ein Problem. Ich hab einen kleinen Bewegungssensor dran gemacht, weiß einer wie man den richtig konfiguriert? Habe mehrere Anleitung getestet und an PIN 7 angeschlossen usw usw..
Ich habe einen AM312 Sensor genommen
Also über car play nicht, aber über eine automation geht das bestimmt. Da du ja direkt das CarPlay/Garagentor Symbol hast auf dem Bildschirm
