Logs begin at Thu 2016-11-03 18:16:42 CET. --
Okt 29 16:49:29 raspberrypi homebridge[386]: [2018-10-29 16:49:29] [ZP] Salon Sonos: set group mute from undefined to false
Okt 29 16:50:51 raspberrypi homebridge[386]: [2018-10-29 16:50:51] Got SIGTERM, shutting down Homebridge...
Okt 29 16:50:51 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Okt 29 16:50:51 raspberrypi homebridge[386]: [2018-10-29 16:50:51] [ZP] cleaning up...
Okt 29 16:50:56 raspberrypi homebridge[386]: [2018-10-29 16:50:56] [ZP] exit
Okt 29 16:50:56 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Okt 29 16:50:56 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Okt 29 16:50:56 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Okt 29 16:50:56 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Okt 29 16:50:56 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Okt 29 16:50:58 raspberrypi homebridge[1077]: [2018-10-29 16:50:58] Loaded config.json with 11 accessories and 5 platforms.
Okt 29 16:50:58 raspberrypi homebridge[1077]: [2018-10-29 16:50:58] ---
Okt 29 16:50:58 raspberrypi homebridge[1077]: [2018-10-29 16:50:58] Loaded plugin: homebridge-config-ui-x
Okt 29 16:50:58 raspberrypi homebridge[1077]: [2018-10-29 16:50:58] Registering platform 'homebridge-config-ui-x.config'
Okt 29 16:50:59 raspberrypi homebridge[1077]: [2018-10-29 16:50:59] Loaded plugin: homebridge-http
Okt 29 16:50:59 raspberrypi homebridge[1077]: [2018-10-29 16:50:59] Registering accessory 'homebridge-http.Http'
Okt 29 16:50:59 raspberrypi homebridge[1077]: [2018-10-29 16:50:59] ---
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Loaded plugin: homebridge-http-switch
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Registering accessory 'homebridge-http-switch.HTTP-SWITCH'
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] ---
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Loaded plugin: homebridge-people
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Registering platform 'homebridge-people.People'
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Registering accessory 'homebridge-people.PeopleAccessory'
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Registering accessory 'homebridge-people.PeopleAllAccessory'
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Loaded plugin: homebridge-telegram
Okt 29 16:51:00 raspberrypi homebridge[1077]: [2018-10-29 16:51:00] Registering platform 'homebridge-telegram.Telegram'
Okt 29 16:51:01 raspberrypi homebridge[1077]: [2018-10-29 16:51:01] Loaded plugin: homebridge-weather-plus
Okt 29 16:51:01 raspberrypi homebridge[1077]: [2018-10-29 16:51:01] Registering platform 'homebridge-weather-plus.WeatherPlus'
Okt 29 16:51:01 raspberrypi homebridge[1077]: [2018-10-29 16:51:01] ---
Okt 29 16:51:01 raspberrypi homebridge[1077]: [2018-10-29 16:51:01] Plugin /usr/local/lib/node_modules/homebridge-zp requires Node version of ^8.12.0 which does not satisfy the current Node version of v10.9.0. You may need to upgrade your installation of Node.
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] Loaded plugin: homebridge-zp
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] Registering platform 'homebridge-zp.ZP'
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] ---
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] Loading 5 platforms...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Config] Initializing config platform...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Config] Spawning homebridge-config-ui-x with PID 1128
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [WeatherPlus] Initializing WeatherPlus platform...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [WeatherPlus] Initializing platform accessory 'Now'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [WeatherPlus] Initializing platform accessory 'Today'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [WeatherPlus] Initializing platform accessory 'In 1 Day'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [WeatherPlus] Initializing platform accessory 'In 2 Days'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [People] Initializing People platform...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [People] Initializing platform accessory 'Beni'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [People] Initializing platform accessory 'Sandra'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [People] Initializing platform accessory 'Anyone'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [People] WebHook: Started server on port '51828'.
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [ZP] Initializing ZP platform...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [ZP] homebridge-zp v0.2.35, node v10.9.0, homebridge v0.4.45
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [ZP] warning: not using recommended node version v8.12.0 LTS
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Telegram] Initializing Telegram platform...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Telegram] TelegramPlatform Plugin Loaded
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Telegram] Found bot in config: "Telegram-Chats"
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Telegram] Initializing platform accessory 'Telegram-Chats'...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] Loading 11 accessories...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad Melody] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad Schlager] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad Top40] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche Srf] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche Melo] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche Schlager] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad Metal] Initializing Http accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche +] Initializing HTTP-SWITCH accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche +] Switch successfully configured...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche -] Initializing HTTP-SWITCH accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Küche -] Switch successfully configured...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad +] Initializing HTTP-SWITCH accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad +] Switch successfully configured...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad -] Initializing HTTP-SWITCH accessory...
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [Bad -] Switch successfully configured...
Okt 29 16:51:03 raspberrypi homebridge[1077]: Load homebridge-telegram.Telegram
Okt 29 16:51:03 raspberrypi homebridge[1077]: [2018-10-29 16:51:03] [homebridge-telegram.Telegram] TelegramPlatform Plugin Loaded
Okt 29 16:51:07 raspberrypi homebridge[1077]: [2018-10-29 16:51:07] [Config] Using Form Authentication
Okt 29 16:51:07 raspberrypi homebridge[1077]: [2018-10-29 16:51:07] [Config] Console v3.8.11 is listening on port 8080.
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Initializing platform accessory 'Salon Sonos'...
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Initializing platform accessory 'Küche Sonos'...
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Initializing platform accessory 'Bad Sonos'...
Okt 29 16:51:08 raspberrypi homebridge[1077]: Setup Payload:
Okt 29 16:51:08 raspberrypi homebridge[1077]: X-HM://0023ISYWYPFPP
Okt 29 16:51:08 raspberrypi homebridge[1077]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
Okt 29 16:51:08 raspberrypi homebridge[1077]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Okt 29 16:51:08 raspberrypi homebridge[1077]: ??????????????
Okt 29 16:51:08 raspberrypi homebridge[1077]: ? 031-45-154 ?
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] Homebridge is running on port 51826.
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Salon Sonos: coordinator for group Salon
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Bad Sonos: coordinator for group Bad
Okt 29 16:51:08 raspberrypi homebridge[1077]: [2018-10-29 16:51:08] [ZP] Küche Sonos: coordinator for group Küche
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Salon Sonos: set power (play/pause) from undefined to false
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Salon Sonos: set current track from undefined to "Radio Rottu Oberwallis"
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Bad Sonos: set power (play/pause) from undefined to false
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Bad Sonos: set current track from undefined to "Buir"
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Küche Sonos: set power (play/pause) from undefined to false
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Küche Sonos: set current track from undefined to "SRF 3"
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Salon Sonos: set group volume from undefined to 21
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Salon Sonos: set group mute from undefined to false
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Bad Sonos: set group volume from undefined to 20
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Bad Sonos: set group mute from undefined to false
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Küche Sonos: set group volume from undefined to 11
Okt 29 16:51:09 raspberrypi homebridge[1077]: [2018-10-29 16:51:09] [ZP] Küche Sonos: set group mute from undefined to false
