Beiträge von nsch
    noch nie gemacht
    Feb 14 20:56:55 raspberrypi homebridge[25927]: [2018-2-14 20:56:55] Please try pasting your config.json file here to validate it: http://jsonlint.com
    Feb 14 20:56:55 raspberrypi homebridge[25927]: /usr/local/lib/node_modules/homebridge/lib/server.js:207
    Feb 14 20:56:55 raspberrypi homebridge[25927]: throw err;
    Feb 14 20:56:55 raspberrypi homebridge[25927]: ^
    Feb 14 20:56:55 raspberrypi homebridge[25927]: SyntaxError: Unexpected end of JSON input
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Object.parse (native)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:201:19)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:57:38)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Module._compile (module.js:570:32)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Object.Module._extensions..js (module.js:579:10)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Module.load (module.js:487:32)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at tryModuleLoad (module.js:446:12)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Function.Module._load (module.js:438:3)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at Module.runMain (module.js:604:10)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at run (bootstrap_node.js:394:7)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at startup (bootstrap_node.js:149:9)
    Feb 14 20:56:55 raspberrypi homebridge[25927]: at bootstrap_node.js:509:3
    Feb 14 20:56:55 raspberrypi systemd[1]: homebridge-people.service: main process exited, code=exited, status=1/FAILURE
    Feb 14 20:56:55 raspberrypi systemd[1]: Unit homebridge-people.service entered failed state.
    Feb 14 20:57:05 raspberrypi systemd[1]: homebridge-people.service holdoff time over, scheduling restart.
    Feb 14 20:57:05 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
    Feb 14 20:57:05 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
    Feb 14 20:57:05 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Feb 14 20:57:06 raspberrypi homebridge[25952]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
    Feb 14 20:57:06 raspberrypi node[25952]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
    Feb 14 20:57:06 raspberrypi homebridge[25952]: *** WARNING *** Please fix your application to use the native API of Avahi!
    Feb 14 20:57:06 raspberrypi node[25952]: *** WARNING *** Please fix your application to use the native API of Avahi!
    Feb 14 20:57:06 raspberrypi homebridge[25952]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
    Feb 14 20:57:06 raspberrypi node[25952]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
    Feb 14 20:57:06 raspberrypi homebridge[25952]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
    Feb 14 20:57:06 raspberrypi node[25952]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
    Feb 14 20:57:06 raspberrypi node[25952]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
    ich bekomme meine People-Hombridge nicht zum laufen.
    Habe Sie in einer separaten Instanz angelegt und div. Sachen die hier stehen probiert.
    Folgenden Fehler habe ich:
    Feb 14 20:35:03 raspberrypi systemd[1]: homebridge-people.service: main process exited, code=exited, status=1/FAILURE
    Feb 14 20:35:03 raspberrypi systemd[1]: Unit homebridge-people.service entered failed state.
    Kennt jemand diesen Fehler und kann mir ein Tipp geben?
    Dann habe ich alles richtig gemacht.
    Wenn ich dann eingebe, kommt eine Fehlermeldung.
    root@raspberrypi:~# sudo systemctl start homebridge-vorwerk.service
    Job for homebridge-vorwerk.service failed. See 'systemctl status homebridge-vorwerk.service' and 'journalctl -xn' for details.
    unter journalctl steht:
    -- Unit homebridge-vorwerk.service has begun starting up.
    Feb 13 21:35:33 raspberrypi systemd[1]: Failed to load environment files: No such file or directory
    Feb 13 21:35:33 raspberrypi systemd[1]: homebridge-vorwerk.service failed to run 'start' task: No such file or directory
    Feb 13 21:35:33 raspberrypi systemd[1]: Failed to start Node.js HomeKit Server.
    -- Subject: Unit homebridge-vorwerk.service has failed
    -- Defined-By: systemd
    -- Support: http://lists.freedesktop.org/mailman/listinfo/systemd-devel
    -- Unit homebridge-vorwerk.service has failed.
    -- The result is failed.
    Feb 13 21:35:33 raspberrypi systemd[1]: Unit homebridge-vorwerk.service entered failed state
    Was mache ich falsch? Fehler in der Config?
    Hallo Nastra,
    habe eine Frage.
    2.)
    - Im Ordner /etc/default eine zusätzliche Datei erstellen zur vorhandenen homebridge Datei
    - Diese heißt in unserem Beispiel homebridge-hue
    - Angelegt wird diese mitsudo touch /etc/default/homebridge-hue
    muss ich hier nach noch: sudo nano /etc/default/homebridge-hue eingeben um diesen Text einzufügen?
    ich habe noch mal alles neu Aufgesetzt und komme jetzt hier nicht weiter?
    pi@raspberrypi:~ $ sudo systemctl start homebridge-people.service
    Job for homebridge-people.service failed. See 'systemctl status homebridge-people.service' and 'journalctl -xn' for details.
    Kann mir einer sagen was falsch ist?
    Danke vorab.
    Weiter vorgehen wie in der Anleitung beschrieben ;)
    Das habe ich auch bis unten hin getan, der Dienst wird auch angezeigt. wenn ich dann in der App schaue, wird mir nur die alte Homebridge Anbindung angezeigt. Bei erneut Start der Homebridge kommt nur der Code von der ersten Instanz die bereits angelegt war (Homebridge(2)).
    root@raspberrypi:/home/pi# sudo systemctl restart homebridge-max -l
    Das war meine letzte Eingabe.
    Probier mal die Date hiermit anzulegen:
    sudo touch /etc/systemd/system/homebridge-XXXXX.service
    und danach sudo nano /etc/systemd/system/homebridge-XXXXX.service um die Datei zu bearbeiten.
    Hat sehr gut funktioniert, Danke.
    Was muss ich noch tun um diese Instanz in der Home App zu sehen?
    Kohle_81:
    Wendest Du regeln an?
    Wenn der letzte aus dem Haus geht dann... oder der erst der nach Hause kommt dann...
    Wenn ja, funktioniert es und welche Schalter hast Du mit einbezogen?
    Festgefahren hat er sich schon mal, weil ein Kabel oder ähnliches im Weg war. Nach einer Befreiung läuft er immer weiter und findet auch immer die Station.
    Obwohl die Station unter einem Möbelstück steht und eigentlich zu wenig Platz hat laut Herstellerangaben.
    wer kann mir helfen?
    Wenn ich versuche den ersten Schritt zu speichern, kommt diese Fehlermeldung:
    [ Error writing etc/systemd/system/homebridge-max.service: No such file or dir ]
    Danke & Gruß
    puhh, das hört sich ja nach ner „montagsproduktion“ an. Ich habe meinen Kobold bald 12 Monate und bin vollends zufrieden. Er navigiert sicher um Hindernisse herum und findet auch die Basisstation zum Aufladen wieder...... Das was du berichtest sollte nicht so die Regel sein. Da würde ich mal bei Vorwerk reklamieren.....
    Sehe ich genau so. Meiner hat die Station immer wieder gefunden.
