hat jemand Erfahrung mit dem IP-Camera Plugin für Homebridge?
Ich habe Sie installiert, finde Sie auch als Homebridge, aber dort wird mir kein Bild angezeigt.
Kann jemand mit diesem Fehler was anfangen:
Feb 15 20:39:40 raspberrypi homebridge[1280]: Or enter this code with your HomeKit app on your iOS device to pair with Homebridge:
Feb 15 20:39:40 raspberrypi homebridge[1280]: ??????????????
Feb 15 20:39:40 raspberrypi homebridge[1280]: ? 031-45-154 ?
Feb 15 20:39:41 raspberrypi homebridge[1280]: [2018-2-15 20:39:41] Homebridge is running on port 51861.
Feb 15 20:39:41 raspberrypi homebridge[1280]: [2018-2-15 20:39:41] Terasse is running on port 43979.
Feb 15 20:39:42 raspberrypi homebridge[1280]: events.js:160
Feb 15 20:39:42 raspberrypi homebridge[1280]: throw er; // Unhandled 'error' event
Feb 15 20:39:42 raspberrypi homebridge[1280]: ^
Feb 15 20:39:42 raspberrypi homebridge[1280]: Error: spawn ffmpeg ENOENT
Feb 15 20:39:42 raspberrypi homebridge[1280]: at exports._errnoException (util.js:1022:11)
Feb 15 20:39:42 raspberrypi homebridge[1280]: at Process.ChildProcess._handle.onexit (internal/child_process.js:193:32)
Feb 15 20:39:42 raspberrypi homebridge[1280]: at onErrorNT (internal/child_process.js:359:16)
Feb 15 20:39:42 raspberrypi homebridge[1280]: at _combinedTickCallback (internal/process/next_tick.js:74:11)
Feb 15 20:39:42 raspberrypi homebridge[1280]: at process._tickCallback (internal/process/next_tick.js:98:9)
Feb 15 20:39:42 raspberrypi systemd[1]: homebridge-test.service: main process exited, code=exited, status=1/FAILURE
Feb 15 20:39:42 raspberrypi systemd[1]: Unit homebridge-test.service entered failed state.
Feb 15 20:39:52 raspberrypi systemd[1]: homebridge-test.service holdoff time over, scheduling restart.
Feb 15 20:39:52 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Feb 15 20:39:52 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
Feb 15 20:39:52 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Feb 15 20:39:53 raspberrypi homebridge[1335]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Feb 15 20:39:53 raspberrypi node[1335]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
Feb 15 20:39:53 raspberrypi node[1335]: *** WARNING *** Please fix your application to use the native API of Avahi!
Feb 15 20:39:53 raspberrypi node[1335]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Feb 15 20:39:53 raspberrypi node[1335]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Feb 15 20:39:53 raspberrypi node[1335]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
Feb 15 20:39:53 raspberrypi homebridge[1335]: *** WARNING *** Please fix your application to use the native API of Avahi!
Feb 15 20:39:53 raspberrypi homebridge[1335]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
Feb 15 20:39:53 raspberrypi homebridge[1335]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
Feb 15 20:39:53 raspberrypi homebridge[1335]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
Feb 15 20:39:55 raspberrypi homebridge[1335]: [2018-2-15 20:39:55] Loaded plugin: homebridge-ip-camera
Feb 15 20:39:55 raspberrypi homebridge[1335]: [2018-2-15 20:39:55] Registering platform 'homebridge-ip-camera.Camera-IP'
Feb 15 20:39:55 raspberrypi homebridge[1335]: [2018-2-15 20:39:55] ---
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Loaded plugin: homebridge-people
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Registering platform 'homebridge-people.People'
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Registering accessory 'homebridge-people.PeopleAccessory'
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Registering accessory 'homebridge-people.PeopleAllAccessory'
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] ---
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Loaded plugin: homebridge-platform-maxcube
Feb 15 20:39:56 raspberrypi homebridge[1335]: [2018-2-15 20:39:56] Registering platform 'homebridge-platform-maxcube.MaxCubePlatform'
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] Loaded plugin: homebridge-vorwerk
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] Registering platform 'homebridge-vorwerk.VorwerkVacuumRobot'
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] ---
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] Loaded config.json with 0 accessories and 1 platforms.
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] Loading 1 platforms...
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] [Camera-IP] Initializing Camera-IP platform...
Feb 15 20:39:57 raspberrypi homebridge[1335]: [2018-2-15 20:39:57] Loading 0 accessories...
Feb 15 20:39:57 raspberrypi homebridge[1335]: Load homebridge-platform-maxcube.MaxCubePlatform
Feb 15 20:39:57 raspberrypi homebridge[1335]: Setup Payload:
Feb 15 20:39:57 raspberrypi homebridge[1335]: X-HM://0023ISYWY642I
Feb 15 20:39:57 raspberrypi homebridge[1335]: Scan this code with your HomeKit app on your iOS device to pair with Homebridge:
