Guten Abend !
möchte gerne das Apple TV Plugin installieren: https://www.npmjs.com/package/homebridge-theater-mode
Bekomme bei der Installation allerdings folgende Fehlermeldung:
USER: pi
DIR: /usr/local/lib/node_modules
CMD: sudo -E -n npm --no-update-notifier install --unsafe-perm homebridge-theater-mode@latest
> [email protected] preinstall /usr/local/lib/node_modules/homebridge-theater-mode/node_modules/sodium
> node install.js --preinstall
Static libsodium was not found at /usr/local/lib/node_modules/homebridge-theater-mode/node_modules/sodium/deps/build/lib/libsodium so compiling libsodium from source.
libtool is required, but wasn't found on this system
Makefile:61: recipe for target 'libsodium' failed
make: *** [libsodium] Error 1
/usr/local/lib/node_modules/homebridge-theater-mode/node_modules/sodium/install.js:287
throw new Error(cmdLine + ' exited with code ' + code);
Error: make libsodium exited with code 2
at ChildProcess.<anonymous> (/usr/local/lib/node_modules/homebridge-theater-mode/node_modules/sodium/install.js:287:19)
at emitTwo (events.js:126:13)
at ChildProcess.emit (events.js:214:7)
at Process.ChildProcess._handle.onexit (internal/child_process.js:198:12)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] preinstall: `node install.js --preinstall`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] preinstall script.
npm ERR! /home/pi/.npm/_logs/2018-07-31T20_11_21_426Z-debug.log
Command failed. Please review log for details
Jemand ne Idee?
