• Hallo, ich weiß nicht ob das Thema hier richtig ist.
    Ich bekomme meine Bridge nicht mehr gestartet.
    Sieht jemand auf den ersten Blick, wo der Fehler evtl. liegen könnte?
    "bridge": {
    "name": "Homebridge",
    "username": "CC:22:3:E3:CE:30",
    "port": 51826,
    "pin": "01-45-154"
    "platforms": [{
    "platform": "People",
    "threshold": 10,
    "anyoneSensor": true,
    "nooneSensor": true,
    "webhookPort": 51828,
    "pingInterval": 10000,
    "ignoreReEnterExitSeconds": 0,
    "people": [{
    "name": "Martin",
    "target": "iPhonevonMaddin",
    "threshold": 10,
    "name": "Ramona",
    "target": "Ramonas-iPhone",
    "threshold": 10,
    "name": "Sabine",
    "target": "iPhone",
    "threshold": 10,
    "name": "Uwe",
    "target": "iPhone-von-Uwe",
    "threshold": 10,
    "platform": "config",
    "name": "Config",
    "port": 8080,
    "auth": "form",
    "theme": "red",
    "sudo": true,
    "log": {
    "method": "custom",
    "platform": "eveatmo",
    "name": "eveatmo platform",
    "extra_co2_sensor": false,
    "co2_alert_threshold": 1000,
    "ttl": 300,
    "auth": {
    "client_id": "5d8d059d6bd262783d4ae29b",
    "client_secret": "XJUpxBgnTeLCJIdWm1jRVGlY2JDYM3hvmK2WmfZbC",
    "username": "[email protected]",
    "password": "S"
    "platform": "Hue",
    "host": "192.168.18.58",
    "users": {
    "ECB5FAFFFE00636D": "VNZ8-G1x9eLjBncJfNerx-cx05hedBHMMUC-"
    "lights": true
    "accessories": [{
    "name": "Xiaomi Mi Robot Vaccum 1st Generation",
    "ip": "192.168.178.28",
    "token": "4c36664474454b33463475484246",
    "pause": false,
    "dock": false,
    "accessory": "XiaomiRoborockVacuum"
    "accessory": "SamsungSmartTV2018",
    "name": "Samsung TV DG",
    "ip_address": "192.168.178.35",
    "mac_address": "40:0:3B:79:87:64"
    "accessory": "PiTemperature",
    "name": "Raspberry PI Temperatur"
    "accessory": "DummySwitch",
    "name": "WT",
    "stateful": true
    "name": "SA",
    "stateful": true
    "name": "SO",
    "stateful": true
    "name": "1 Minute",
    "time": 60000
  • Code
    Error: Parse error on line 119:
    ...: 60000 } ]
    Expecting '}', ',', got 'EOF'
    ja aber damit kann ich nix anfangen, er will wohl ein Komma oder eine klammer. da tut sich aber nix, wenn ich das einfüge
  • raspberrypi homebridge[5643]: SyntaxError: Unexpected end of JSON input
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at JSON.parse (<anonymous>)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:212:19)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:38)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:32:16)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Oct 08 22:38:04 raspberrypi homebridge[5643]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Oct 08 22:38:04 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
    Oct 08 22:38:04 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Oct 08 22:38:14 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
    Oct 08 22:38:14 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 85.
    Oct 08 22:38:14 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
    Oct 08 22:38:14 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Oct 08 22:38:16 raspberrypi homebridge[5666]: [10/8/2019, 10:38:16 PM] There was a problem reading your config.json file.
    Oct 08 22:38:16 raspberrypi homebridge[5666]: [10/8/2019, 10:38:16 PM] Please try pasting your config.json file here to validate it: http://jsonlint.com
    Oct 08 22:38:16 raspberrypi homebridge[5666]: /usr/local/lib/node_modules/homebridge/lib/server.js:218
    Oct 08 22:38:16 raspberrypi homebridge[5666]: throw err;
    Oct 08 22:38:16 raspberrypi homebridge[5666]: ^
    Oct 08 22:38:16 raspberrypi homebridge[5666]: SyntaxError: Unexpected end of JSON input
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at JSON.parse (<anonymous>)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Server._loadConfig (/usr/local/lib/node_modules/homebridge/lib/server.js:212:19)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:38)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:32:16)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Module._compile (internal/modules/cjs/loader.js:778:30)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Module.load (internal/modules/cjs/loader.js:653:32)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
    Oct 08 22:38:16 raspberrypi homebridge[5666]: at Function.Module._load (internal/modules/cjs/loader.js:585:3)
    Oct 08 22:38:16 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
    Oct 08 22:38:16 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Diese Meldungen bekomme ich, wenn ich die Bridge starten will.
    Ich verstehe nur Bahnhof
    "bridge": {
    "port": 51826,
    "pin": "01-45-154"
    "platforms": [{
    "threshold": 10,
    "people": [{
    "name": "Martin",
    "threshold": 10,
    "name": "Ramona",
    "threshold": 10,
    "name": "Sabine",
    "target": "iPhone",
    "threshold": 10,
    "name": "Uwe",
    "threshold": 10,
    "name": "Config",
    "port": 8080,
    "auth": "form",
    "theme": "red",
    "sudo": true,
    "log": {
    "method": "custom",
    "ttl": 300,
    "auth": {
    "password": "S"
    "platform": "Hue",
    "users": {
    "lights": true
    "accessories": [{
    "pause": false,
    "dock": false,
    "name": "WT",
    "stateful": true
    "name": "SA",
    "stateful": true
    "name": "SO",
    "stateful": true
    "name": "1 Minute",
    "time": 60000
    Schau dir in Ruhe deine config an. Denn wenn eine offene Klammer ist, muss diese auch irgendwann geschlossen werden. Bei dir haben insgesamt 3 Klammern gefehlt....
  • Die Zeile 119 ist die letzte Zeile deiner config und endet mit einer eckigen Klammer. Meine Config endet mit einer geschweiften Klammer. Ich würde eine Zeile hinzufügen und dann die Klammer eintragen siehe nachfolgendes Beispiel:
    "accessory": "mi-flower-care",
    "name": "EZ Dummy",
    "deviceId": "C4:7C:8D:6A:EA:DC",
    "interval": 300
  • Error: Accessories must be created with a non-empty displayName.
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at new Accessory (/usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/Accessory.js:49:27)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Server._createAccessory (/usr/local/lib/node_modules/homebridge/lib/server.js:445:21)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:413:32)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at /usr/local/lib/node_modules/homebridge/node_modules/hap-nodejs/lib/util/once.js:16:19
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at PeoplePlatform.accessories (/usr/local/lib/node_modules/homebridge-people/index.js:58:9)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Server._loadPlatformAccessories (/usr/local/lib/node_modules/homebridge/lib/server.js:403:20)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:341:16)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
    Oct 08 22:54:48 raspberrypi homebridge[2097]: [10/8/2019, 10:54:48 PM] Got SIGTERM, shutting down Homebridge...
    Oct 08 22:54:53 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
    Oct 08 22:54:53 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    klappt leider noch nicht, jetzt kommt der folgende Fehler
  • Probier es mal so....
    Und auch wenn ich da eigentlich kein Prinzipienreiter bin, wenn Du die Quellcode Funktion nutzt ist der Beitrag leichter zu lesen...
