als ich das live log von homebridge mal verfolgt habe stellte ich fest, dass meine über das hue-plugin eingebundenen osram lightify gartenspots dauern folgenden Befehl erhalten:
pi@raspberrypi:~ $ sudo journalctl -f -u homebridge
-- Logs begin at Mo 2017-10-16 20:17:01 CAT. --
Okt 23 18:51:04 raspberrypi homebridge[22842]: [2017-10-23 18:51:04] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 18:52:24 raspberrypi homebridge[22842]: [2017-10-23 18:52:24] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 18:53:44 raspberrypi homebridge[22842]: [2017-10-23 18:53:44] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 18:54:54 raspberrypi homebridge[22842]: [2017-10-23 18:54:54] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 18:56:14 raspberrypi homebridge[22842]: [2017-10-23 18:56:14] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 18:59:55 raspberrypi homebridge[22842]: [2017-10-23 18:59:55] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 19:00:40 raspberrypi homebridge[22842]: [2017-10-23 19:00:40] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 19:01:10 raspberrypi homebridge[22842]: [2017-10-23 19:01:10] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 19:01:40 raspberrypi homebridge[22842]: [2017-10-23 19:01:40] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 19:02:45 raspberrypi homebridge[22842]: [2017-10-23 19:02:45] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 19:03:40 raspberrypi homebridge[22842]: [2017-10-23 19:03:40] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 19:08:21 raspberrypi homebridge[22842]: [2017-10-23 19:08:21] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 19:09:41 raspberrypi homebridge[22842]: [2017-10-23 19:09:41] [Hue] Gartenspot: set homekit status fault from 1 to 0
Okt 23 19:12:11 raspberrypi homebridge[22842]: [2017-10-23 19:12:11] [Hue] Gartenspot: set homekit status fault from 0 to 1
Okt 23 19:12:36 raspberrypi homebridge[22842]: [2017-10-23 19:12:36] [Hue] Gartenspot: set homekit status fault from 1 to 0
Die Spots gehen in Wirklichkeit nicht an und aus, aber über das log werden ständig die Meldungen registriert. Die Spots sind in keiner Regel, Bedingung oder Automation eingebunden.
Hat hier jemand eine Idee, was die Ursache sein könnte?
Ich werde mal den Strom abschalten und wieder an schalten. Mal schauen, ob dies hilft.
