Hi zusammen,
ich habe jetzt mehrere Male nach der Smartapfel Anleitung die HB installiert und nach der Anleitung scheinst es nicht zu gehen. Ich wundere mich etwas, dass es keine anderen User gibt, die das Problem haben. Aber ich habe mich ganz genau dran gehalten, aber es kommt immer wieder zu Fehlern.
Ich einem Reboot erscheinen keine Geräte im Webinterface.
Loading logs using "custom" method...
CMD: journalctl -o cat -n 500 -f -u homebridge
Started Node.js HomeKit Server.
[7/6/2020, 16:19:43] Loaded config.json with 0 accessories and 2 platforms.
[7/6/2020, 16:19:43] ---
[7/6/2020, 16:19:44] Loaded plugin: [email protected]
[7/6/2020, 16:19:44] Registering platform 'homebridge-config-ui-x.config'
[7/6/2020, 16:19:44] ---
[7/6/2020, 16:19:44] The plugin "homebridge-fritz-platform" requires a Homebridge version of ^0.4.49 which does not satisfy the current Homebridge version of 1.1.1. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
[7/6/2020, 16:19:44] The plugin "homebridge-fritz-platform" requires Node version of ^10.15.3 which does not satisfy the current Node version of v12.18.2. You may need to upgrade your installation of Node.
[7/6/2020, 16:19:45] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[7/6/2020, 16:19:45] ---
[7/6/2020, 16:19:45] Loading 2 platforms...
[7/6/2020, 16:19:45] [Config] Initializing config platform...
[7/6/2020, 16:19:45] [Config] Spawning homebridge-config-ui-x with PID 498
[7/6/2020, 16:19:45] [FritzPlatform] Initializing FritzPlatform platform...
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] **************************************************************
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] FritzPlatform v4.1.0 by SeydX
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] GitHub: https://github.com/SeydX/homebridge-fritz-platform
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] Email: [email protected]
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] start success...
[7/6/2020, 16:19:45] [FritzPlatform] [INFO] Auto Device Search is enabled, searching for devices in network...
Setup Payload:
X-HM://0023ISYWY18JH
│ 031-45-154 │
[7/6/2020, 16:19:45] Homebridge is running on port 51826.
[7/6/2020, 16:19:50] [Config] Homebridge Config UI X v4.23.2 is listening on :: port 8080
[7/6/2020, 16:19:50] [FritzPlatform] [INFO] Initializing config...
[7/6/2020, 16:19:50] [FritzPlatform] [INFO] Found 4 active devices...
[7/6/2020, 16:19:50] [FritzPlatform] [ERROR] An error occured while checking config!
Dann sind im Webinterface aber keine Geräte zu sehen.
Wenn ich jetzt einen HB Neustart mache kommt es zu vielen Fehlern aber dafür sind die Geräte da. Hat jmd. eine Idee, woran das liegen kann?
[7/6/2020, 16:46:34] [Config] Executing restart command: sudo -n systemctl restart homebridge
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart homebridge
pam_unix(sudo:session): session opened for user root by (uid=0)
Stopping Node.js HomeKit Server...
[7/6/2020, 16:46:34] Got SIGTERM, shutting down Homebridge...
homebridge.service: Main process exited, code=exited, status=143/n/a
homebridge.service: Failed with result 'exit-code'.
Stopped Node.js HomeKit Server.
homebridge.service: Found left-over process 498 (node) in control group while starting unit. Ignoring.
This usually indicates unclean termination of a previous run, or service implementation deficiencies.
homebridge.service: Found left-over process 1427 (sh) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 1428 (sudo) in control group while starting unit. Ignoring.
homebridge.service: Found left-over process 1433 (systemctl) in control group while starting unit. Ignoring.
pam_unix(sudo:session): session closed for user root
[7/6/2020, 16:46:40] Loaded config.json with 0 accessories and 2 platforms.
[7/6/2020, 16:46:40] ---
[7/6/2020, 16:46:41] Loaded plugin: [email protected]
[7/6/2020, 16:46:41] Registering platform 'homebridge-config-ui-x.config'
[7/6/2020, 16:46:41] ---
[7/6/2020, 16:46:41] The plugin "homebridge-fritz-platform" requires a Homebridge version of ^0.4.49 which does not satisfy the current Homebridge version of 1.1.1. You may need to update this plugin (or Homebridge) to a newer version. You may face unexpected issues or stability problems running this plugin.
[7/6/2020, 16:46:41] The plugin "homebridge-fritz-platform" requires Node version of ^10.15.3 which does not satisfy the current Node version of v12.18.2. You may need to upgrade your installation of Node.
[7/6/2020, 16:46:41] Registering platform 'homebridge-fritz-platform.FritzPlatform'
[7/6/2020, 16:46:41] Loading 2 platforms...
[7/6/2020, 16:46:41] [Config] Initializing config platform...
[7/6/2020, 16:46:41] [Config] Spawning homebridge-config-ui-x with PID 1458
[7/6/2020, 16:46:41] [FritzPlatform] Initializing FritzPlatform platform...
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] **************************************************************
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] FritzPlatform v4.1.0 by SeydX
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] GitHub: https://github.com/SeydX/homebridge-fritz-platform
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] Email: [email protected]
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] start success...
[7/6/2020, 16:46:41] [FritzPlatform] [INFO] Auto Device Search is enabled, searching for devices in network...
Setup Payload:
│ 031-45-154 │
[7/6/2020, 16:46:41] Homebridge is running on port 51826.
[7/6/2020, 16:46:45] [Config] Homebridge Config UI X v4.23.2 is listening on :: port 8080
[7/6/2020, 16:46:46] [FritzPlatform] [INFO] Initializing config...
[7/6/2020, 16:46:46] [FritzPlatform] [INFO] Found 4 active devices...
[7/6/2020, 16:46:46] [FritzPlatform] [ERROR] An error occured while checking config!
"bridge": {
"name": "Homebridge",
"manufacturer": "homebridge.io",
"model": "homebridge",
"port": 51826,
"pin": "031-45-154"
"platforms": [
"platform": "config",
"name": "Config",
"port": 8080,
"auth": "form",
"theme": "red",
"sudo": true,
"log": {
"method": "custom",
"platform": "FritzPlatform",
"devices": {
"FRITZ!WLAN Repeater 1750E": {
"active": false,
"host": "192.168.178.XX",
"port": 49000,
"username": "",
"password": "",
"type": "",
"master": false,
"mesh": false,
"readOnly": false,
"options": false
"FRITZ!Box 7590 (UI)": {
"active": false,
"host": "192.168.178.1",
"port": 49000,
"username": "XXX",
"password": "XXX",
"type": "",
"master": false,
"mesh": false,
"readOnly": false,
"options": false
"smarthome": {
"DECT 200": {
"active": true,
"ain": "087610374",
"tempSensor": true,
"devType": "switch"
"DECT 200 OL": {
"active": true,
"ain": "087610180",
"tempSensor": true,
"devType": "switch"
"Test Contact Sensor": {
"active": false,
"ain": "01234567890",
"devType": "contact"
"Test Thermostat Device": {
"active": false,
"heatValue": 5,
"coolValue": 5,
"windowSensor": false,
"devType": "thermostat"
"Test Outlet Device": {
"active": false,
"tempSensor": false,
"devType": "switch"
"callmonitor": {
"active": false,
"ip": "0.0.0.0",
"port": 1012,
"country": "",
"incomingTo": [],
"outgoingFrom": []
"presence": {
"user": [
"active": false,
"name": "Test User",
"address": "0.0.0.0"
"anyone": false,
"offDelay": 90,
"onDelay": 15,
"ping": false
"wol": [
"active": false,
"name": "Test Device",
"address": "00:00:00:00:00:00"
"phoneBook": {
"active": false,
"blacklists": []
"alarm": {
"active": false,
"telNr": "",
"duration": 30
"wakeup": {
"active": false,
"internNr": "",
"duration": 30
"ringlock": {
"active": false,
"DECTphones": 1,
"start": "11:00",
"end": "22:00"
"broadband": {
"active": false,
"measureTime": 5
"extReboot": {
"active": false,
"cmdOn": "",
"cmdOff": ""
"telegram": {
"active": false,
"token": "",
"chatID": "",
"presence": {
"in": "",
"out": "",
"anyoneIn": "",
"anyoneOut": ""
"callmonitor": {
"incoming": "",
"disconnected": ""
"alarm": {
"activated": "",
"deactivated": ""
"extReboot": {
"start": "",
"finish": ""
"polling": 10,
"timeout": 10,
"clearCache": false,
"debug": false,
"disableAutoSearch": false,
"disableAutoConfig": false
"accessories": [],
"id": "config"
