misst ausverkauft
Beiträge von restore
Vielleicht verändert dein Router die IP ´s ?
War bei mir so.
Wo ist der unterscheid zwischen homebridge-people-arp und homebridge-people ?
also ich habe auch ab und an Probleme mit den People,
manchmal findet er mich gar nicht. Habe es mal in IP umgeändert statt Handyname.
Auch die Homebridge war aufeinmal nicht erreichbar.
Jemand eine Idee?
Alles anzeigen[1/7/2020, 10:52:09 AM] [Fernseher] webOS - disconnected from TV [1/7/2020, 11:14:31 AM] [People] Changed occupancy state for 192.168.178.28 to false. Last successful ping 2020-01-07T10:59:28+01:00 , last webhook none . [1/7/2020, 4:42:14 PM] [People] Changed occupancy state for 192.168.178.31 to true. Last successful ping 2020-01-07T16:42:14+01:00 , last webhook none . [1/7/2020, 5:04:54 PM] [Config] Homebridge restart request received [1/7/2020, 5:04:55 PM] [Config] Executing restart command: sudo -n systemctl restart homebridge homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart homebridge pam_unix(sudo:session): session opened for user root by (uid=0) Stopping Node.js HomeKit Server... [1/7/2020, 5:04:55 PM] Got SIGTERM, shutting down Homebridge... homebridge.service: Main process exited, code=exited, status=143/n/a Stopped Node.js HomeKit Server. homebridge.service: Unit entered failed state. homebridge.service: Failed with result 'exit-code'. Started Node.js HomeKit Server. pam_unix(sudo:session): session closed for user root [1/7/2020, 5:05:04 PM] Loaded config.json with 2 accessories and 4 platforms. [1/7/2020, 5:05:04 PM] --- [1/7/2020, 5:05:04 PM] Loaded plugin: homebridge-config-ui-x [1/7/2020, 5:05:04 PM] Registering platform 'homebridge-config-ui-x.config' [1/7/2020, 5:05:04 PM] --- *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. *** WARNING *** Please fix your application to use the native API of Avahi! *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> [1/7/2020, 5:05:06 PM] Loaded plugin: homebridge-dacp [1/7/2020, 5:05:06 PM] Registering platform 'homebridge-dacp.DACP' [1/7/2020, 5:05:06 PM] --- [1/7/2020, 5:05:06 PM] Loaded plugin: homebridge-dummy [1/7/2020, 5:05:06 PM] Registering accessory 'homebridge-dummy.DummySwitch' [1/7/2020, 5:05:06 PM] --- [1/7/2020, 5:05:06 PM] Loaded plugin: homebridge-fakebulb [1/7/2020, 5:05:06 PM] Registering accessory 'homebridge-fakebulb.FakeBulb' [1/7/2020, 5:05:06 PM] --- [1/7/2020, 5:05:07 PM] Loaded plugin: homebridge-nest [1/7/2020, 5:05:07 PM] Registering platform 'homebridge-nest.Nest' [1/7/2020, 5:05:07 PM] --- [1/7/2020, 5:05:08 PM] Loaded plugin: homebridge-people [1/7/2020, 5:05:08 PM] Registering platform 'homebridge-people.People' [1/7/2020, 5:05:08 PM] Registering accessory 'homebridge-people.PeopleAccessory' [1/7/2020, 5:05:08 PM] Registering accessory 'homebridge-people.PeopleAllAccessory' [1/7/2020, 5:05:08 PM] --- [1/7/2020, 5:05:08 PM] ==================== [1/7/2020, 5:05:08 PM] ERROR LOADING PLUGIN homebridge-ranger: [1/7/2020, 5:05:08 PM] Error: Cannot find module 'bluetooth-hci-socket' at Function.Module._resolveFilename (internal/modules/cjs/loader.js:655:15) at Function.Module._load (internal/modules/cjs/loader.js:580:25) at Module.require (internal/modules/cjs/loader.js:711:19) at require (internal/modules/cjs/helpers.js:14:16) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-ranger/node_modules/noble/lib/hci-socket/hci.js:6:26) at Module._compile (internal/modules/cjs/loader.js:805:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:816:10) at Module.load (internal/modules/cjs/loader.js:672:32) at tryModuleLoad (internal/modules/cjs/loader.js:612:12) at Function.Module._load (internal/modules/cjs/loader.js:604:3) at Module.require (internal/modules/cjs/loader.js:711:19) at require (internal/modules/cjs/helpers.js:14:16) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-ranger/node_modules/noble/lib/hci-socket/bindings.js:9:11) at Module._compile (internal/modules/cjs/loader.js:805:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:816:10) at Module.load (internal/modules/cjs/loader.js:672:32) at tryModuleLoad (internal/modules/cjs/loader.js:612:12) at Function.Module._load (internal/modules/cjs/loader.js:604:3) at Module.require (internal/modules/cjs/loader.js:711:19) at require (internal/modules/cjs/helpers.js:14:16) at module.exports (/usr/local/lib/node_modules/homebridge-ranger/node_modules/noble/lib/resolve-bindings.js:13:12) at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-ranger/node_modules/noble/index.js:2:49) [1/7/2020, 5:05:08 PM] ==================== [1/7/2020, 5:05:10 PM] Loaded plugin: homebridge-weather-plus [1/7/2020, 5:05:14 PM] Registering platform 'homebridge-weather-plus.WeatherPlus' [1/7/2020, 5:05:14 PM] --- [1/7/2020, 5:05:14 PM] Loaded plugin: homebridge-webos-tv [1/7/2020, 5:05:14 PM] Registering accessory 'homebridge-webos-tv.webostv' [1/7/2020, 5:05:14 PM] --- [1/7/2020, 5:05:14 PM] Loading 4 platforms... [1/7/2020, 5:05:14 PM] [Nest] Initializing Nest platform... [1/7/2020, 5:05:14 PM] [Nest] Fetching Nest devices. [1/7/2020, 5:05:14 PM] [Config] Initializing config platform... [1/7/2020, 5:05:14 PM] [Config] Spawning homebridge-config-ui-x with PID 27288 [1/7/2020, 5:05:14 PM] [Wetter] Initializing WeatherPlus platform... [1/7/2020, 5:05:14 PM] [Wetter] Adding station with weather service Dark Sky named 'Now' [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'Now'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 1 Day'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 2 Days'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 3 Days'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 4 Days'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 5 Days'... [1/7/2020, 5:05:15 PM] [Wetter] Initializing platform accessory 'In 6 Days'... [1/7/2020, 5:05:15 PM] [People] Initializing People platform... [1/7/2020, 5:05:15 PM] [People] Initializing platform accessory 'Maurice'... [1/7/2020, 5:05:15 PM] [People] Initializing platform accessory 'Lisa'... [1/7/2020, 5:05:15 PM] [People] Initializing platform accessory 'Anyone'... [1/7/2020, 5:05:15 PM] [People] WebHook: Started server on port '51828'. [1/7/2020, 5:05:15 PM] Loading 2 accessories... [1/7/2020, 5:05:15 PM] [Licht Decke] Initializing FakeBulb accessory... [1/7/2020, 5:05:15 PM] [Licht Decke] Starting a fake bulb device with name 'Lamp1'... [1/7/2020, 5:05:15 PM] [Fernseher] Initializing webostv accessory... [1/7/2020, 5:05:16 PM] [Fernseher] webOS - Error: connect EHOSTUNREACH 192.168.178.32:3000 [1/7/2020, 5:05:20 PM] [Nest] initing home_away_sensor "Home/Away": deviceId: 4fa3c860-e1fd-11e9-918f-12c20a107032 structureId: 4fa3c860-e1fd-11e9-918f-12c20a107032 [1/7/2020, 5:05:20 PM] [Nest] initing protect "Living Room": deviceId: 6416660000C8E22C structureId: 4fa3c860-e1fd-11e9-918f-12c20a107032 [1/7/2020, 5:05:20 PM] [Nest] Initializing platform accessory 'Home/Away'... [1/7/2020, 5:05:20 PM] [Nest] Initializing platform accessory 'Living Room'... Setup Payload: X-HM://0023ISYWYHEBF Scan this code with your HomeKit app on your iOS device to pair with Homebridge: -
Homekit ist echt mies. Ich warte auf Update
Ahhh gut zu wissen.
Danke für den Hinweis.
Aber halt bei Logitech ist das Abo deutlich teurer als bei Apple
Hat noch jemand die Circle nativ in HK eingebunden? Ich bin mit Funktion und Zuverlässigkeit extrem unzufrieden und würde gern zur normalen App zurück. Geht das?
Das geht halt nicht. Das steht immer da und du bestätigst es auch sobald du von Circle2 auf Homekit umsteigst das es nicht zurück geht. Finde ich auch schwach
Das ist wiedermal ein fall für Apple Support APP.
Vielleicht wissen die mehr
keiner erfahrung damit?
Naja es liegt natürlich auch an der Geschwindigkeit des Wlan.
Ich persönlich hab ein gang schlechtes Netz und muss ca. 1 Minute warten bis es aufgebaut ist.
Ich habe aber das Problem, man kann die Kamera nicht mehr einstellen von 720p auf 1080p oder?
In den Einstellungen ist leider nichts zu finden.Das war bei der Logitech App besser.Hat jemand eine Idee ?
46,39 € Bei Amazon derzeit 55 €
Nächster Preis66,89
€ 59,90
+ Versand: € 6,99(Vorkasse, Kreditkarte, PayPal)
Hallo Torben,
vielen Dank für deine Ausführliche Erklärung.
Das habe ich mir auch schon gedacht. Unseres Internet ist sehr mies hier. Da muss ich mir eh Gedanken machen wie ich alles verlege. Was für Netzwerkkabel ? und und und
Der AirPlay Lautsprecher ist immer mal wieder für den Preis irgendwo zu haben. Wohl auch Abverkauf. Allerdings nicht unbedingt schlecht.
Klang finde ich sehr okay. HomeKit Tasten funktionieren. Doodles können praktisch sein und das Design des Lautsprecher ist auch nicht das schlechteste. Verarbeitung super.
Natürlich auch Geschmacksache, aber ich finde in Flur, Küche oder Badezimmer kann der Triby seinen berechtigten Platz finden.
https://www.kaufen333.de/Invox…0B2QfgEAkYASABEgKFXfD_BwE
97,95 €
restore : Es gibt nur immer eine Aussage, die für diesem Moment gilt.
Vielleicht wird HomeKit noch der Boom, vielleicht wird HomeKit in 7 Jahren eingestellt?
Dein Haus hast du aber Jahrzehnte!!
Keiner kann dir sagen, welches System in 10 oder 20 Jahren die Nase vorne hat.
Deshalb kann ich dir nur den Tip geben, so flexibel wie möglich zu bauen bzw. zu renovieren.
- Verlege keine festen Kabel, sondern mach eine Leerverrohrung.- Dimensioniere deine Sicherungskästen lieber etwas größer.
- Lieber mehr Dosen als zu wenig.
liebe Grüße
TorbenDanke.
Das ist mal eine Antwort die mir etwas weiter hilft.
Dann werde ich wohl auf Fibaro Single Switch zurück greifen.
Wie ich es mit den Rolläden mache, muss ich erstmal nachforschen
Vielen Dank smartHansen
Hallo.
Ich würde mich mal hier einhaken wenn ich darf.
Ich bin gerade dabei ein Haus komplett umzubauen. Das ganze Haus soll natürlich Smart Home integriert werden mit Homekit.
Bevor ich jetzt Stromkabel verlege, bevor ich Lichtschalter kaufe und anbaue und und und. Was ist am sinnvollsten ? Lichtschalter von Eve Light Switch - Smarter Lichtschalter wo ich finde die sind überteuert ? Oder doch ein Fibaro Single Switch dazwischen legen? Oder doch eine einfache,günstige Variante die ihr mir empfehlen könnt ?
Was aber nicht geht, in der Küche?
Siehe Anhang nur 17 Crad
Obwohl richtig 20 Crad eingestellt ist HSV-Steph
Wo ist def Fehler“?
Lad dir mal die app Nicegram runter.
Ist ein Telegram Clone. Da kannst du die chat id direkt sehen. 😉
Danke.
Das habe ich gemacht und muss feststellen das die HTTP-Token ID genau gleich ist wie die Chat ID,
da hat doch schon was nicht hin?
ich bin nochmal Schritt zu Schritt durchgegangen.
Ich bekommen aber keine CHAT ID.
Siehe Anhang. Wo ist Fehler noch ?
Wir werden es nie erfahren ...
