Beiträge von nsch
    Kann diesen Fehler auch jemand lesen?
    Mar 28 17:47:44 raspberrypi homebridge[6905]: undefined:1
    Mar 28 17:47:44 raspberrypi homebridge[6905]: ^
    Mar 28 17:47:44 raspberrypi homebridge[6905]: SyntaxError: Unexpected token u in JSON at position 0
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at JSON.parse (<anonymous>:null:null)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at Request._callback (/usr/local/lib/node_modules/homebridge-synology-surveillance-homemode/index.js:35:33)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at self.callback (/usr/local/lib/node_modules/homebridge-synology-surveillance-homemode/node_modules/request/request.js:186:22)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at Request.emit (events.js:180:13)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at Request.onRequestError (/usr/local/lib/node_modules/homebridge-synology-surveillance-homemode/node_modules/request/request.js:878:8)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at ClientRequest.emit (events.js:180:13)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at TLSSocket.socketErrorListener (_http_client.js:394:9)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at TLSSocket.emit (events.js:180:13)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at onwriteError (_stream_writable.js:427:12)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at onwrite (_stream_writable.js:449:5)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at _destroy (internal/streams/destroy.js:39:7)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at TLSSocket.Socket._destroy (net.js:548:3)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at TLSSocket.destroy (internal/streams/destroy.js:32:8)
    Mar 28 17:47:44 raspberrypi homebridge[6905]: at WriteWrap.afterWrite (net.js:846:10)
    Mar 28 17:47:44 raspberrypi systemd[1]: homebridge-homemode.service: main process exited, code=exited, status=1/FAILURE
    Mar 28 17:47:44 raspberrypi systemd[1]: Unit homebridge-homemode.service entered failed state.
    Mar 28 17:47:55 raspberrypi systemd[1]: homebridge-homemode.service holdoff time over, scheduling restart.
    Mar 28 17:47:55 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
    Mar 28 17:47:55 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
    Mar 28 17:47:55 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Mar 28 17:47:55 raspberrypi homebridge[6941]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
    Mar 28 17:47:55 raspberrypi node[6941]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
    Mar 28 17:47:55 raspberrypi node[6941]: *** WARNING *** Please fix your application to use the native API of Avahi!
    Mar 28 17:47:55 raspberrypi node[6941]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
    Mar 28 17:47:55 raspberrypi node[6941]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
    Mar 28 17:47:55 raspberrypi node[6941]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
    Mar 28 17:47:55 raspberrypi homebridge[6941]: *** WARNING *** Please fix your application to use the native API of Avahi!
    Mar 28 17:47:55 raspberrypi homebridge[6941]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
    Mar 28 17:47:55 raspberrypi homebridge[6941]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi.
    Mar 28 17:47:55 raspberrypi homebridge[6941]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…node&f=DNSServiceRegister>
    Nastra ist das hier wo der Code stehen soll?
    Mar 28 17:45:30 raspberrypi homebridge[6082]: [2018-3-28 17:45:30] [Broadlink RM] Learn getSwitchState: undefined
    Mar 28 17:45:30 raspberrypi homebridge[6082]: [2018-3-28 17:45:30] [Broadlink RM] TV On/Off getSwitchState: undefined
    Mar 28 17:45:30 raspberrypi homebridge[6082]: [2018-3-28 17:45:30] [Broadlink RM] Scan Frequency getSwitchState: undefined
    Mar 28 17:45:33 raspberrypi homebridge[6082]: [2018-3-28 17:45:33] [Broadlink RM] [INFO] Learn Code (Couldn't learn code, device not found)
    kann mir jemand helfen?
    Mar 28 15:56:45 raspberrypi systemd[1]: homebridge-homemode.service: main process exited, code=exited, status=1/FAILURE
    Mar 28 15:56:45 raspberrypi systemd[1]: Unit homebridge-homemode.service entered failed state.
    Mar 28 15:56:45 raspberrypi systemd[1]: homebridge-people.service: main process exited, code=exited, status=1/FAILURE
    Mar 28 15:56:45 raspberrypi systemd[1]: Unit homebridge-people.service entered failed state.
    Mar 28 15:56:45 raspberrypi homebridge[3107]: /usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
    Mar 28 15:56:45 raspberrypi homebridge[3107]: throw ex;
    Mar 28 15:56:45 raspberrypi homebridge[3107]: ^
    Mar 28 15:56:45 raspberrypi homebridge[3107]: Error: The module '/usr/local/lib/node_modules/homebridge/node_modules/mdns/build/Release/dns_sd_bindings.node'
    Mar 28 15:56:45 raspberrypi homebridge[3107]: was compiled against a different Node.js version using
    Mar 28 15:56:45 raspberrypi homebridge[3107]: NODE_MODULE_VERSION 48. This version of Node.js requires
    Mar 28 15:56:45 raspberrypi homebridge[3107]: NODE_MODULE_VERSION 51. Please try re-compiling or re-installing
    Mar 28 15:56:45 raspberrypi homebridge[3107]: the module (for instance, using `npm rebuild` or`npm install`).
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Object.Module._extensions..node (module.js:598:18)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Module.load (module.js:488:32)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at tryModuleLoad (module.js:447:12)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Function.Module._load (module.js:439:3)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Module.require (module.js:498:17)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at require (internal/module.js:20:19)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:24:20)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Module._compile (module.js:571:32)
    Mar 28 15:56:45 raspberrypi homebridge[3107]: at Object.Module._extensions..js (module.js:580:10)
    Mar 28 15:56:45 raspberrypi homebridge[3113]: /usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:35
    Mar 28 15:56:45 raspberrypi homebridge[3113]: throw ex;
    Mar 28 15:56:45 raspberrypi homebridge[3113]: ^
    Zu den accessories:
    funktioniert dein HomeMode?
    Kann jemand mit diesem Fehler was anfangen?
    Mar 25 22:02:30 raspberrypi node[2147]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
    Mar 25 22:02:30 raspberrypi node[2147]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only su...of Avahi.
    Mar 25 22:02:30 raspberrypi node[2147]: *** WARNING *** Please fix your application to use the native API of Avahi!
    Mar 25 22:02:30 raspberrypi node[2147]: *** WARNING *** For more information see <http://0pointer.de/avahi-compa…&e=node&f=DNSS...Register>
    Jetzt habe ich es auch hinbekommen.
    Mann muss den my_id@get_id_bot in die Gruppe einladen und der teilt einem die Gruppen ID mit, wichtig dabe ist die Gruppen ID mit dem - vor den Zahlen einzugeben.
