Loading logs using "systemd" method...
CMD: sudo -n journalctl -o cat -n 500 -f -u homebridge
Started Node.js HomeKit Server.
[5/15/2019, 9:46:41 AM] Loaded config.json with 0 accessories and 2 platforms.
[5/15/2019, 9:46:41 AM] ---
[5/15/2019, 9:46:41 AM] Loaded plugin: homebridge-config-ui-x
[5/15/2019, 9:46:41 AM] Registering platform 'homebridge-config-ui-x.config'
[5/15/2019, 9:46:41 AM] Loaded plugin: homebridge-fritz
[5/15/2019, 9:46:44 AM] Registering platform 'homebridge-fritz.Fritz!Box'
[5/15/2019, 9:46:44 AM] ---
[5/15/2019, 9:46:44 AM] Loading 2 platforms...
[5/15/2019, 9:46:44 AM] [Config] Initializing config platform...
[5/15/2019, 9:46:44 AM] [Config] Spawning homebridge-config-ui-x with PID 470
[5/15/2019, 9:46:44 AM] [My FritzBox] Initializing Fritz!Box platform...
[5/15/2019, 9:46:44 AM] [My FritzBox] Initializing Fritz!Box platform accessories failed - wrong user credentials?
[5/15/2019, 9:46:53 AM] [Config] Console v4.4.0 is listening on :: port 8080
[5/15/2019, 10:06:42 AM] [Config] Homebridge restart request received
[5/15/2019, 10:06:43 AM] [Config] Executing restart command: sudo -n systemctl restart homebridge
homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/systemctl restart homebridge
pam_unix(sudo:session): session opened for user root by (uid=0)
Stopping Node.js HomeKit Server...
[5/15/2019, 10:06:43 AM] Got SIGTERM, shutting down Homebridge...
homebridge.service: Main process exited, code=exited, status=143/n/a
Stopped Node.js HomeKit Server.
homebridge.service: Unit entered failed state.
homebridge.service: Failed with result 'exit-code'.
pam_unix(sudo:session): session closed for user root
[5/15/2019, 10:06:51 AM] Loaded config.json with 0 accessories and 2 platforms.
[5/15/2019, 10:06:51 AM] ---
[5/15/2019, 10:06:51 AM] Loaded plugin: homebridge-config-ui-x
[5/15/2019, 10:06:51 AM] Registering platform 'homebridge-config-ui-x.config'
[5/15/2019, 10:06:51 AM] Loaded plugin: homebridge-fritz
[5/15/2019, 10:06:53 AM] Registering platform 'homebridge-fritz.Fritz!Box'
[5/15/2019, 10:06:53 AM] ---
[5/15/2019, 10:06:53 AM] Loading 2 platforms...
[5/15/2019, 10:06:53 AM] [Config] Initializing config platform...
[5/15/2019, 10:06:53 AM] [Config] Spawning homebridge-config-ui-x with PID 771
[5/15/2019, 10:06:53 AM] [My FritzBox] Initializing Fritz!Box platform...
[5/15/2019, 10:06:55 AM] [My FritzBox] Initializing Fritz!Box platform accessories failed - wrong user credentials?
[5/15/2019, 10:07:02 AM] [Config] Console v4.4.0 is listening on :: port 8080
[5/15/2019, 10:11:02 AM] [Config] Homebridge restart request received
[5/15/2019, 10:11:03 AM] [Config] Executing restart command: sudo -n systemctl restart homebridge
[5/15/2019, 10:11:03 AM] Got SIGTERM, shutting down Homebridge...
[5/15/2019, 10:11:07 AM] [Config] Homebridge restart request received
[5/15/2019, 10:11:08 AM] [Config] Executing restart command: sudo -n systemctl restart homebridge
[5/15/2019, 10:11:11 AM] Loaded config.json with 0 accessories and 2 platforms.
[5/15/2019, 10:11:11 AM] ---
[5/15/2019, 10:11:11 AM] Loaded plugin: homebridge-config-ui-x
[5/15/2019, 10:11:11 AM] Registering platform 'homebridge-config-ui-x.config'
[5/15/2019, 10:11:11 AM] Loaded plugin: homebridge-fritz
[5/15/2019, 10:11:13 AM] Registering platform 'homebridge-fritz.Fritz!Box'
[5/15/2019, 10:11:13 AM] ---
[5/15/2019, 10:11:13 AM] Loading 2 platforms...
[5/15/2019, 10:11:13 AM] [Config] Initializing config platform...
[5/15/2019, 10:11:13 AM] [Config] Spawning homebridge-config-ui-x with PID 846
[5/15/2019, 10:11:13 AM] [My FritzBox] Initializing Fritz!Box platform...
[5/15/2019, 10:11:15 AM] [My FritzBox] Initializing Fritz!Box platform accessories failed - wrong user credentials?
[5/15/2019, 10:11:22 AM] [Config] Console v4.4.0 is listening on :: port 8080
[5/15/2019, 10:18:05 AM] [Config] Failed load accessories from Homebridge: Error: connect ECONNREFUSED 127.0.0.1:51826
[5/15/2019, 10:18:08 AM] [Config] Failed load accessories from Homebridge: Error: connect ECONNREFUSED 127.0.0.1:51826
homebridge : TTY=pts/0 ; PWD=/var/homebridge ; USER=root ; COMMAND=/bin/journalctl -o cat -n 500 -f -u homebridge
