erstmal danke für das tolle Forum hier. Anhand der Anleitung konnte ich wenigstens schon mal erfolgreich Homebridge mit ner fakebulb verwenden ![]()
Aber leider habe ich anscheinend einen NODE-Versionskonflikt. Hier mal mein Homebridge Startlog ...
ov 24 15:20:17 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Nov 24 15:20:19 raspberrypi homebridge[4611]: [11/24/2018, 3:20:19 PM] Loaded config.json with 0 accessories and 2 platforms.
Nov 24 15:20:19 raspberrypi homebridge[4611]: [11/24/2018, 3:20:19 PM] ---
Nov 24 15:20:19 raspberrypi homebridge[4611]: [11/24/2018, 3:20:19 PM] Loaded plugin: homebridge-config-ui-x
Nov 24 15:20:19 raspberrypi homebridge[4611]: [11/24/2018, 3:20:19 PM] Registering platform 'homebridge-config-ui-x.config'
Nov 24 15:20:19 raspberrypi homebridge[4611]: [11/24/2018, 3:20:19 PM] Plugin /usr/local/lib/node_modules/homebridge-hue requires Node version of ^10.13.0 which does not satisfy the current Node version of v11.2.0. You may need to upgrade your installation of Node.
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] Loaded plugin: homebridge-hue
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] Registering platform 'homebridge-hue.Hue'
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] ---
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] Loading 2 platforms...
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] [Config] Initializing config platform...
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] [Config] Spawning homebridge-config-ui-x with PID 4639
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] [Hue] Initializing Hue platform...
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] [Hue] homebridge-hue v0.11.0, node v11.2.0, homebridge v0.4.45
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] [Hue] warning: not using recommended node version v10.13.0 LTS
Nov 24 15:20:20 raspberrypi homebridge[4611]: [11/24/2018, 3:20:20 PM] Loading 0 accessories...
Nov 24 15:20:24 raspberrypi homebridge[4611]: [11/24/2018, 3:20:24 PM] [Config] Using Form Authentication
Nov 24 15:20:24 raspberrypi homebridge[4611]: [11/24/2018, 3:20:24 PM] [Config] Console v3.9.0 is listening on port 8080.
Nov 24 15:20:26 raspberrypi homebridge[4611]: [11/24/2018, 3:20:26 PM] [Hue] Philips hue: Philips BSB002 bridge v1810251352, api v1.28.0
Nov 24 15:20:26 raspberrypi homebridge[4611]: [11/24/2018, 3:20:26 PM] [Hue] Philips hue: warning: not using recommended Hue bridge api version 1.27.0
Nov 24 15:20:26 raspberrypi homebridge[4611]: [11/24/2018, 3:20:26 PM] [Hue] Philips hue: 5 accessories
Nov 24 15:20:29 raspberrypi homebridge[4611]: [11/24/2018, 3:20:29 PM] [Hue] 192.***.***.80: bridge request 1: get /config
Nov 24 15:20:29 raspberrypi homebridge[4611]: [11/24/2018, 3:20:29 PM] [Hue] 192.***.***.80: bridge communication error EHOSTUNREACH on 192.***.***.80
Nov 24 15:20:29 raspberrypi homebridge[4611]: [11/24/2018, 3:20:29 PM] [Hue] 192.***.***.185: bridge request 1: get /config
Nov 24 15:20:29 raspberrypi homebridge[4611]: [11/24/2018, 3:20:29 PM] [Hue] 192.***.***.185: bridge communication error EHOSTUNREACH on 192.***.***.185
Die HUE Bridge ist ganz normal im Netz erreichbar. Die config.json ist auch mit von der HUE-Brigde erstelltem User eingerichtet.
Kann mir einer sagen, wie ich diesen Fehler lösen kann?
Wäre super wenn irgendjemand hier mir die Befehle geben könnte um z.B. das Downgrade von Node v0.11.0 auf v10.13.0 durchzuführen.
Und was es mit recommended HUE Bridge api 1.27.0 auf sich hat, da ich wohl die 1.28.0 habe.
Ich danke schon mal im Voraus.
Marco
