ich habe das Harmony-Plug-In installiert und nach einem Neustart bekomme ich den Web-Login nicht mehr angezeigt.
Ich habe die Config.JSON schon hoch und runter gesucht und den Fehler nicht gefunden.
Kann es noch an was anderem liegen?
May 26 22:16:21 raspberrypi homebridge[3078]: [5/26/2020, 22:16:21] There was a problem reading your config.json file.
May 26 22:16:21 raspberrypi homebridge[3078]: [5/26/2020, 22:16:21] Please try pasting your config.json file here to validate it: http://jsonlint.com
May 26 22:16:21 raspberrypi homebridge[3078]: SyntaxError: Unexpected token ] in JSON at position 1456
May 26 22:16:21 raspberrypi homebridge[3078]: at JSON.parse (<anonymous>)
May 26 22:16:21 raspberrypi homebridge[3078]: at Function._loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:217:21)
May 26 22:16:21 raspberrypi homebridge[3078]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:119:44)
May 26 22:16:21 raspberrypi homebridge[3078]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:54:18)
May 26 22:16:21 raspberrypi homebridge[3078]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
May 26 22:16:21 raspberrypi homebridge[3078]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
May 26 22:16:21 raspberrypi homebridge[3078]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
May 26 22:16:21 raspberrypi homebridge[3078]: at Module.load (internal/modules/cjs/loader.js:977:32)
May 26 22:16:21 raspberrypi homebridge[3078]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
May 26 22:16:21 raspberrypi homebridge[3078]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
May 26 22:16:21 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
May 26 22:16:21 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
May 26 22:16:31 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
May 26 22:16:31 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 269.
May 26 22:16:31 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
May 26 22:16:31 raspberrypi systemd[1]: Started Node.js HomeKit Server.
May 26 22:16:33 raspberrypi homebridge[3094]: [5/26/2020, 22:16:33] There was a problem reading your config.json file.
May 26 22:16:33 raspberrypi homebridge[3094]: [5/26/2020, 22:16:33] Please try pasting your config.json file here to validate it: http://jsonlint.com
May 26 22:16:33 raspberrypi homebridge[3094]: SyntaxError: Unexpected token ] in JSON at position 1456
May 26 22:16:33 raspberrypi homebridge[3094]: at JSON.parse (<anonymous>)
May 26 22:16:33 raspberrypi homebridge[3094]: at Function._loadConfig (/usr/local/lib/node_modules/homebridge/src/server.ts:217:21)
May 26 22:16:33 raspberrypi homebridge[3094]: at new Server (/usr/local/lib/node_modules/homebridge/src/server.ts:119:44)
May 26 22:16:33 raspberrypi homebridge[3094]: at cli (/usr/local/lib/node_modules/homebridge/src/cli.ts:54:18)
May 26 22:16:33 raspberrypi homebridge[3094]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
May 26 22:16:33 raspberrypi homebridge[3094]: at Module._compile (internal/modules/cjs/loader.js:1133:30)
May 26 22:16:33 raspberrypi homebridge[3094]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1153:10)
May 26 22:16:33 raspberrypi homebridge[3094]: at Module.load (internal/modules/cjs/loader.js:977:32)
May 26 22:16:33 raspberrypi homebridge[3094]: at Function.Module._load (internal/modules/cjs/loader.js:877:14)
May 26 22:16:33 raspberrypi homebridge[3094]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
May 26 22:16:33 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
May 26 22:16:33 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
