-25% auf den gesamten Netatmo Onlineshop bis 26.11.2018
Beiträge von DJay
skrollme Hat einen Fix gezaubert.
[email protected]??????????
eveatmo macht seit langer Zeit ohne Probleme bei mir, nun mal wieder Sorgen und die gesamte Homebridge stoppt.
Lösung? Keine Ahnung von meiner Seite. Ich denke das liegt vor allem dann auch am Netatmo-Server selbst, oder?
Alles anzeigenNov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: /usr/local/lib/node_modules/homebridge-eveatmo/accessory/eveatmo-weather-accessory.js:25 Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: if(device.dashboard_data.Pressure) { Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: ^ Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: TypeError: Cannot read property 'Pressure' of undefined Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at new EveatmoWeatherAccessory (/usr/local/lib/node_modules/homebridge-eveatmo/accessory/eveatmo-weather-accessory.js:25:30) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.buildAccessory (/usr/local/lib/node_modules/homebridge-eveatmo/device/weatherstation-device.js:61:12) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.<anonymous> (/usr/local/lib/node_modules/homebridge-eveatmo/lib/netatmo-device.js:85:26) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at Array.forEach (<anonymous>) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.buildAccessories (/usr/local/lib/node_modules/homebridge-eveatmo/lib/netatmo-device.js:72:32) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.<anonymous> (/usr/local/lib/node_modules/homebridge-eveatmo/lib/netatmo-device.js:39:10) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.<anonymous> (/usr/local/lib/node_modules/homebridge-eveatmo/lib/netatmo-device.js:53:7) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at WeatherstationDeviceType.<anonymous> (/usr/local/lib/node_modules/homebridge-eveatmo/device/weatherstation-device.js:51:5) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at netatmo.<anonymous> (/usr/local/lib/node_modules/homebridge-eveatmo/node_modules/netatmo/netatmo.js:227:14) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at Request.self.callback (/usr/local/lib/node_modules/homebridge-eveatmo/node_modules/request/request.js:185:22) Nov 20 16:09:25 raspberrypi-3BPlus homebridge[1361]: at Request.emit (events.js:182:13) Nov 20 16:09:25 raspberrypi-3BPlus systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Nov 20 16:09:25 raspberrypi-3BPlus systemd[1]: homebridge.service: Unit entered failed state. Nov 20 16:09:25 raspberrypi-3BPlus systemd[1]: homebridge.service: Failed with result 'exit-code'. -
Erstmal herzlich Willkommen und eine gute Zeit hier für Dich.
Vielleicht helfen Dir zum Thema Z-way auch folgende Beiträge zum einlesen.
[Workaround] Pi 3 B + | z-wave.me | RaZberry | Raspbian stretch
Homekit,homebrigde Z-wave, openhab...
Allerdings, wie schon von @Melvil gesagt, wären ein paar Details aus dem Log und ggf. weitere Infos nützlich, so dass Dir dann gezielt Unterstützung angeboten werden kann.
Viel Spaß und Erfolg weiterhin. Und "Backup" nicht vergessen, damit Du immer wieder auf ein funktionierendes System zurück kannst wenn beim Ausprobieren mal etwas nicht klappt.
Ich hab mein "Projekt" jetzt erstmal damit vervollständigt, dass mir "öffnen" ja auch signalisiert wird in HomeKit.
Und für meinen Fall, ist das sogar noch besser.
Auch wenn Dank Nello one die Paketlieferdienste im Bedarfsfall ohne Probleme freien Zugang ins Haus und bis vor unsere Wohnungstür haben, klapp es leider mit dem schwächsten Glied in der Kette (Mensch), leider nicht immer die Sendung dort abzulegen.
Die Zustelldienste haben eine schriftliche Abstellgenehmigung, so dass diese eine Sendung auch in meiner Abwesenheit vor der Wohnungstür platzieren dürfen.
Nello one gibt den Lieferdiensten den entsprechenden zeitlich begrenzten Zugang in das Haus. Also eigentlich sollte nichts dagegen sprechen, dass dies auch so klappt.
Da ich in den ersten Wochen einfach mal testen wollte wie das so mit den Zustellern in der Praxis funktioniert, stand ich machmal wie ein Stalker hinter der Wohnungstür und beobachtete durch den Spion wie hilflos die Zusteller dann doch manchmal sind. Das Zusammenspiel von "Wer hat denn die Haustür geöffnet, aber warum nimmt niemand das Paket persönlich entgegen?", scheint für den ein oder anderen Zusteller doch sehr irritierend zu sein. Auch wenn er eigentlich nur das Paket scannen muss um zu sehen, dass eben besagte Abstellgenehmigung mit Anweisung vorliegt.
Ich möchte es mir nicht nehmen lassen zu sagen, dass die Dienste mit denen es zu 99% funktioniert DHL, UPS und DPD sind. Hermes und Amazon Logistics machen sich selbst und mir das Leben dauerhaft schwer.
Also musste eine Smart Home Lösung zusätzlich zu Nello her! Wie bekomme ich in meiner Abwesenheit den Zustellern die es bis vor die Wohnungstür geschafft haben signalisiert, dass sie das Paket einfach auch vor die Wohnungstür legen sollen?
Hier die Lösung, zumindest für mich. Ob die Zusteller für Lichtreize empfänglich sind, wird sich in den dann nun folgenden Wochen zeigen.
Komponenten:
12 Volt Netzteil, LED-Pfeile SMD 12V, Klingeldraht, USB-Kabel abgeschnitten, Philips LivingWhites Adapter
Jetzt nur noch den LED Pfeil, den Klingeldraht und das abgeschnittene USB Kabel miteinander verbunden und ab in das 12 Volt Netzteil. Leuchtet!?
Leider gibt es die Living Whites Adapter nicht mehr im Handel. Glücklicherweise hatte ich noch einen in der Schublade gebunkert (neben den anderen die fleissig hier in der Wohnung mit Lampen aktiv im Einsatz sind). Der Living Whites Adapter wird von der Hue App als Lampe/Steckdose direkt erkannt.
Der Philips Adapter ist für mein Setup in soweit wichtig, da ich angeschlossene Leuchten über IFTTT blinken lassen kann, was mit HomeKit nativ so ja leider nicht möglich ist. Mir zumindest nicht bekannt.
Also nun in IFTTT einen Webhook eingerichtet mit dem Trigger "Door Drop" versehen. If Webhook event "Door Drop" then "Hue Adapter blinken lassen".
Und das Ganze natürlich in die config.json, damit es mir als Schalter in HomeKit angezeigt wird.
Code: https://github.com/sergeturgeon/homebridge-notification{ "accessory": "Notification", "name": "Notify Door Drop", "ifttt_api_key": "xxxxx", "ifttt_event": "Door Drop", "ifttt_message": "Door Drop Alarm ausgelöst", "ifttt_mute_notification_interval_in_sec": 20 },Vor meiner Wohnungstür ist ein Bewegungsmelder, der Bewegung natürlich in HomeKit signalisiert.
Durch das geniale Nello one Plugin von lukasroegner bekomme ich in HomeKit signalisiert wenn jemand and der Haustür klingelt, bzw. Nello öffnet.
Ich habe noch einen Delay Switch 10 Minuten zusätzlich in HomeKit angelegt, den ich für die gesamte Automation/Regeln brauche.
Code: https://github.com/nitaybz/homebridge-delay-switch{ "accessory": "DelaySwitch", "name": "Door Drop 10 Min", "delay": 600000 },Nun geht es an die Automationen/Regeln in HomeKit.
1. Szene anlegen: Door Drop -> Notify Door Drop (Webhook IFTTT Switch) einschalten.
2. Auslöser: Schloss "Haustür" (Nello one) = offen/entsperrt -> Door Drop 10 Min (Delay Switch) einschalten.
3. Auslöser: Bewegung Hausflur = Bewegung, -> Bedingung Door Drop 10 (Delay Switch) = Ein, -> Szene: Notify Door Drop
Was nun abläuft ist, wenn jemand klingelt und Nello öffnet automatisch die Tür, dann wird der Delay Switch 10 Min aktiviert.
Steht der Zusteller dann bei mir im Stockwerk vor der Wohnungstür, wird die Bewegung registriert und geprüft ob der Delay Switch 10 Min aktiviert ist.
Wenn dieser Switch aktiv ist, was er ja durch das öffnen durch Nello für 10 Minuten ist, wird der Webhook an IFTTT gesendet, ausgelöst durch die Szene Notify Door Drop. Diese lässt dann den LED Pfeil blinken für 10-15 Sekunden.
Also bekommt der Zusteller jetzt eine eindeutige Einladung bitte das Paket dort abzulegen, wo es blinkt. Zudem ist da dann auch noch ein netter Aufkleber an der Stelle platziert, den ich zur Motivation auch noch designt habe.
Und wenn das dann den Zustellern von Hermes und Amazon Logistics immer noch nicht reicht, geh ich demnächst die Tiere im Zoo trainieren. Das ist dann eventuell erfolgreicher und entspannter, auch ohne Smart Home Kreativität.
Mein kleines Projekt ist vielleicht dem Ein- oder Anderen ein Anreiz auch mal wieder kreativ zu werden. Viel Spaß und bei Fragen, natürlich gerne fragen.
Vielleicht steh ich gerade völlig auf der Leitung, daher die Frage hier...
Ich bekomme zum nello Plugin auch die "Haustür" als Bewegungsmelder angezeigt was super ist.
Ich verstehe es so, dass wenn jemand klingelt an der Haustür, der Sensor damit ausgelöst und Bewegung erkannt wird.
Irgendwie passiert da bei mir aber nichts. Alles andere funktioniert einwandfrei.
Was übersehe ich?
Danke vorab.
Alles anzeigen{ "platform": "NelloPlatform", "name": "Haustür", "username": "[email protected]", "password": "xxxxx", "clientId": "xxxxxxxx-xxxx-xxxx-xxxx-xxxxxxxxxxxx", "lockTimeout": 5000, "locationUpdateInterval": 3600000, "exposeReachability": true, "motionSensor": true, "motionTimeout": 5000, "alwaysOpenSwitch": false, "videoDoorbell": true, "video": { "stream": "-re -i rtsp://184.72.239.149/vod/mp4:BigBuckBunny_175k.mov", "snapshotImage": "https://i.imgur.com/naQ5MuW.png", "maxWidth": 1280, "maxHeight": 720, "maxFPS": 30, "vcodec": "h264_omx" }, "homekitUser": "xxxxx" }, -
Das ist natürlich ganz individuell. Wenn man aber mit Zwave nix zu tun hat, muss es natürlich auch kein Zwave V3 sein.
Den Raspberry dazu zu bringen Zwave zu sprechen, ist ja auch nochmal eine kleine Investition mit einem Hardware Modul.Mir war die Auto Unlock Funktion wichtig, also dass sich die Tür öffnet ohne etwas am iPhone bestätigen zu müssen. Das geht mit dem HomeKit V3 nicht.
Added noGo lines button
Added extra care navigation button
Added syncing cleaning options from last run
Added option to disable background state update completely
Changed goto dock button is now always off
Changed error handling
Changed debug messages
Updated node-botvac dependency to 0.1.6
Removed extra care navigation option parameter (is now a button)
Läuft!
Danke naofireblade -
Es gibt homebridge-info.
Aber selbst nicht probiert.
Kannst ja mal berichten PhoenixDH
Alles anzeigenPlugin for homebridge providing stats about the running instance.
homebridge-info acts as a server, that emits several infos about the homebridge instance. You can subscribe and display these in the browser frontend.
Features:
Memory usage
Uptime
OS info
update check for homebridge version
Wenn Du ihn kaufen willst, lass ihn zu mir schicken und ich geb ihn weiter nach AUT. Daran soll's im Zweifel nicht liegen.
Ob "Klimaanlage" wirklich die passende HomeKit Kategorie ist weiß ich zwar nicht, aber zumindest sollte der VOCOlinc – FLOWERBUD Ultraschall Luftbefeuchter mit nativem HomeKit solche Workarounds wie hier nun ersparen.
https://www.vocolinc.com/products/flowerbud
Externer Inhalt youtu.beInhalte von externen Seiten werden ohne Ihre Zustimmung nicht automatisch geladen und angezeigt.Durch die Aktivierung der externen Inhalte erklären Sie sich damit einverstanden, dass personenbezogene Daten an Drittplattformen übermittelt werden. Mehr Informationen dazu haben wir in unserer Datenschutzerklärung zur Verfügung gestellt.
Aktuell bin ich auf iOS und tvOS 12.1.1 Beta (2) und musste heute feststellen, dass das doch noch vielleicht eine zu frühe Entscheidung war auf die Beta zu wechseln.
Für den HomePod gibt es zwar keine Beta, aber dort habe ich das selbe Problem wie auf dem Apple TV 4k mit tvOS 12.1.1.
Siri meint baum Aufruf einer vorhandenen Szene, dass diese noch gar nicht konfiguriert ist. Oder bei einer anderen Szene schaltet Sie z.B. das Licht nicht so, wie es tatsächlich in der Szene hinterlegt ist.
Seltsam ist, dass wenn ich die gleiche Szene(n) über das iPhone X mit iOS 12.1.1 aufrufe, funktioniert alles einwandfrei.
Zudem haben heute alle Automationen gestoppt. Egal ob durch Auslöser, Sensor, Gerät oder Zeit, es wird keine Automation mehr ausgelöst oder automatisch gestartet.
Die Automationen sind zwar alle noch vorhandne, einige davon haben aber in der Konfiguration z.B. Geräte verloren, so dass ich alle nochmal überarbeitet habe. Dennoch startet keine einzige Automation.
Das mal soweit als Erfahrungsbericht. Vielleicht hat noch ein ungeduldiger Nutzer wie ich auch ein Update auf den Geräten gemacht und kann ähnliches berichten?
naofireblade Hallo.. hab gesehen Du bist an einem Update für "NoGo Lines and options sync" dran.
NPM sagt noch 0.4.7, was ja die vorherige Version ist. Bis Du noch am werkeln und das update ist später verfügbar?
Und bitte demnächst die "Suche" bemühen und nicht hier im dazu nicht passenden Thread das Thema in die Länge ziehen. Danke dafür.
woher bekommt man den die iD vom Sensor?
Alles anzeigenKONFIGURATION DES FEINSTAUBSENSORS
- Station mit Stromkabel anschließen
- Die Station versucht, sich auf den konfigurierten WLAN-Accesspoint zu verbinden. Klappt dies nicht, öffnet der Sensor einen Accesspoint mit dem Namen Feinstaubsensor-ID, wobei ID die ChipID (dezimal, im Beispiel unten die 13597771) ist.
Diese ID bitte unbedingt notieren, diese wird für die Anmeldung des Sensors benötigt! - Mit diesem Accesspoint verbinden. Kurz warten, bis die Verbindung hergestellt ist.
Android: Falls die Verbindung sofort wieder getrennt wird muss evtl. unter ‚Verbindungen-WLAN-Erweitert‘die Option ‚Intelligenter Netzwechsel‘ (englisch ‚Smart network switch‘) deaktiviert werden. - Dann im Browser die Seite http://192.168.4.1/ aufrufen, dort kann der Sensor konfiguriert werden: http://192.168.4.1/ –> Konfigurieren
Bitte beachten: Es braucht eventuell ein paar Versuche, bis der NodeMCU sich mit dem Heim-WLAN verbindet. Bitte nicht ungeduldig werden und es solange versuchen, bis es klappt. Der Chip kann auch über ein Smartphone konfiguriert werden. Wenn die Konfiguration des Sensors funktioniert hat, ist diese Seite nicht mehr erreichbar
Beispiel: Ansicht der Sensors als Router mit der Nummer des ESP8266
- Unter ‚Konfigurieren‘ die SSID (Name des Heim-WLANs) und den Netzwerksicherheitsschlüssel (unter Windows) bzw. das WLAN-Passwort des Heim-WLANs eintragen, speichern
- Für Feinstaubsensoren nach dieser Anleitung muss nichts weiter geändert werden
- Nach dem Speichern wird der Sensor neu gestartet und ist auf diesem Weg nicht mehr erreichbar
Wenn keine weiteren Änderungen vorgenommen worden als das Eintragen der WLAN-Daten, kann der Sensor nach ca. 10 Minuten auf den folgenden Seiten ‚getestet‘ werden. Gesucht werden muss auf diesen Seiten nach der ChipID (im Bespiel oben die 13597771).
Sensordaten: http://www.madavi.de/sensor/graph.php
WLAN-Signal: http://www.madavi.de/sensor/signal.php
Wenn Du die Kaffeemaschine immer über HomeKit steuerst also an/ausschaltest, wird Dir der Status auch wohl immer korrekt angezeigt.
Außer die Maschine schaltet sich nach x Stunden ja von selbst aus.
Die Maschine meldet Ihren Status über IFTTT nicht zurück. D.h. Du wirst hier immer einen anderen Status sehen, wenn Du die Maschine manuell bedienst.
Ich hab die Maschine daher in meine "Gute Nacht" Szene eingebunden, so dass am Abend definitiv immer der Schalter in HK auf aus ist, so dass am nächsten Tag alles frisch starten kann.
Aber auch wenn in HK die Maschine als aus gekennzeichnet ist, Du sie aber manuell eingeschaltet hast, lassen sich die Kaffeeprogramme ja dennoch über HK weiterhin starten.
Ich hoffe, dass ist was Du gemeint hast.
Besonders diplomatisch finde ich Deinen Satz "the AUTO UNLOCK function is working as shit."
Eine Änderung an der Range hat aber auch in meinen Versuchen in der Vergangenheit nix gebracht.
Ich hab mal heute das Lock mit neuen Batterien ausgestattet, so dass es anstelle von 30% wieder bei 100% ist.
Und auch der Beacon hat eine neue Batterie bekommen.
Dabei ist mir dann aber auch noch eingefallen, ich hab noch einen anderen Beacon den ich konfigurieren kann und den habe ich jetzt mal auf einen Range von 70 Metern mit Transmition Power (Tx) Strong 4 dBm gestellt und dazu noch auf einen Advertising Intervall von 100ms. Das ist der kürzeste Intervall der sich einstellen lässt in der Estimote App. Also das Ding feuert eigentlich nun kontinuierlich auf stärkster Leistung und in kürzestem Abstand. Die Batterie hält dann wohl max. nur noch 3 Monate, aber für einen Test in den nächsten Tagen, ist das ja auch mal einen Versuch wert.
