[4/27/2020, 2:38:13 PM] Got SIGTERM, shutting down Homebridge...
[4/27/2020, 2:38:18 PM] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
[4/27/2020, 2:38:23 PM] [HB Supervisor] Restarting Homebridge...
[4/27/2020, 2:38:23 PM] [HB Supervisor] Starting Homebridge with extra flags: -P /homebridge/node_modules
[4/27/2020, 2:38:24 PM] [HB Supervisor] Started Homebridge with PID: 3145
[4/27/2020, 2:38:24 PM] Loaded config.json with 2 accessories and 4 platforms.
[4/27/2020, 2:38:24 PM] ---
[4/27/2020, 2:38:24 PM] ====================
[4/27/2020, 2:38:24 PM] ERROR LOADING PLUGIN homebridge-fritz:
[4/27/2020, 2:38:24 PM] Error: Plugin /homebridge/node_modules/homebridge-fritz requires a HomeBridge version of ^1.0.0 which does not satisfy the current HomeBridge version of 0.4.53. You may need to upgrade your installation of HomeBridge.
at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:57:11)
at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:153:14)
at Array.forEach (<anonymous>)
at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:145:22)
at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:57:24)
at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:32:16)
at Module._compile (internal/modules/cjs/loader.js:1156:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1176:10)
at Module.load (internal/modules/cjs/loader.js:1000:32)
[4/27/2020, 2:38:24 PM] Loaded plugin: homebridge-magichome
homebridge API version: 2.4
[4/27/2020, 2:38:24 PM] Registering accessory 'homebridge-magichome.MagicHome'
[4/27/2020, 2:38:24 PM] Loaded plugin: homebridge-panasonictv
[4/27/2020, 2:38:24 PM] Registering accessory 'homebridge-panasonictv.TV'
[4/27/2020, 2:38:24 PM] Loaded plugin: homebridge-tplink-smarthome
[4/27/2020, 2:38:24 PM] Registering platform 'homebridge-tplink-smarthome.TplinkSmarthome'
[4/27/2020, 2:38:25 PM] Loaded plugin: homebridge-yamaha-home
[4/27/2020, 2:38:25 PM] Registering platform 'homebridge-yamaha-home.yamaha-home'
[4/27/2020, 2:38:25 PM] ---
[4/27/2020, 2:38:25 PM] Loaded plugin: homebridge-config-ui-x
[4/27/2020, 2:38:25 PM] Registering platform 'homebridge-config-ui-x.config'
[4/27/2020, 2:38:25 PM] Loading 4 platforms...
[4/27/2020, 2:38:25 PM] [Config] Initializing config platform...
[4/27/2020, 2:38:25 PM] [Config] Running in Service Mode
[4/27/2020, 2:38:25 PM] Error: The requested platform 'FRITZ!Box' was not registered by any plugin.
at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:134:13)
at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:327:45)
at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
at Function.Module._load (internal/modules/cjs/loader.js:899:14)
at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
at internal/main/run_main_module.js:18:47
[4/27/2020, 2:38:25 PM] Got SIGTERM, shutting down Homebridge...
[4/27/2020, 2:38:30 PM] [HB Supervisor] Homebridge Process Ended. Code: 143, Signal: null
