Der hue entwickler hatte in einem issue mal folgendes geschrieben:
The ETIMEDOUT and EHOSTDOWN errors indicate that homebridge-hue cannot connect to the Hue bridge, typically because the Hue bridge or the network connection the Hue bridge is down. It's generated on every communication attempt with the Hue bridge, which is every heartbeat seconds when homebridge-hue polls the Hue bridge.
What type of server do you run homebridge on? Is this server connected to the network by wire or by WiFi? What is your home bridge configuration? What is your Hue bridge config?
https://github.com/ebaauw/homebridge-hue/issues/15
Hier bin ich aber mit meinen Kenntnissen am Ende, evtl. hat @natra noch eine Idee, der schon mal mitgelesen hat?
