Und was sagt das syslog ?
Homebridge Image - Raspbian Stretch Lite - Raspberry Pi
Apr 16 05:34:24 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 16 05:34:24 raspberrypi systemd[6782]: homebridge.service: Failed at step EXEC spawning /usr/local/bin/homebridge: No such file or directory
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=203/EXEC
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Apr 16 05:34:24 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 16 05:34:34 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Apr 16 05:34:34 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Die Homebridge selbst scheint nicht installiert zu sein.
Installier diese mal über:sudo npm i homebridge@latest –g
Ich dachte zwar, dass ich über
./hbridge_new.sh install
Homebridge bereits installiert habe, aber ich habe es mit deinem Befehl ein Weiteres mal getan.
Nun steht folgendes im syslog
Apr 16 21:35:31 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Apr 16 21:35:31 raspberrypi homebridge[1353]: module.js:540
Apr 16 21:35:31 raspberrypi homebridge[1353]: throw err;
Apr 16 21:35:31 raspberrypi homebridge[1353]: ^
Apr 16 21:35:31 raspberrypi homebridge[1353]: Error: Cannot find module '../build/Release/dns_sd_bindings'
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._resolveFilename (module.js:538:15)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._load (module.js:468:25)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module.require (module.js:587:17)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at require (internal/module.js:11:18)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/node_modules/mdns/lib/dns_sd.js:32:22)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module._compile (module.js:643:30)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Object.Module._extensions..js (module.js:654:10)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Module.load (module.js:556:32)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at tryModuleLoad (module.js:499:12)
Apr 16 21:35:31 raspberrypi homebridge[1353]: at Function.Module._load (module.js:491:3)
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Unit entered failed state.
Apr 16 21:35:31 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Apr 16 21:35:41 raspberrypi systemd[1]: homebridge.service: Service hold-off time over, scheduling restart.
Apr 16 21:35:41 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
leider bist Du jetzt der 2te wo mit install die homebridge nicht suaber installiert wird.
Das muss ich mir nochmal anschauen.
Ich hatte einmal einen Effekt wo beider Abfrage nach npm Version ? homebridge Version? ich sehr schnell mit enter bestätigt habe.
das dann in der Zeile "wird installiert npm und dann müll stand, da kahm aber auch eine Fehlermeldeung.
Diese sieht man natürlich nur wen man davor sitzen bleibt.
Moin,
ich habe auch versucht Homebridge mit dem "Jessie mit Kernel 4.9" und dem "Stretch (lite) mit Kernel: 4.9" Image auf einem Raspberry Pi Model B Revision 2.0 aufzusetzen und bekomme folgenden Fehler:
Codepi@hbridge2:~ $ sudo systemctl status homebridge ? homebridge.service - Node.js HomeKit Server Loaded: loaded (/etc/systemd/system/homebridge.service; enabled) Active: activating (auto-restart) (Result: signal) since So 2018-04-22 20:12:42 CEST; 9s ago Process: 778 ExecStart=/usr/local/bin/homebridge $HOMEBRIDGE_OPTS (code=killed, signal=SEGV) Main PID: 778 (code=killed, signal=SEGV) Apr 22 20:12:42 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 22 20:12:42 hbridge2 systemd[1]: Unit homebridge.service entered failed state.
Der Fehler kommt bei beiden Images.
Weiß eventuell jemand was der Fehler bedeutet und wie ich ihn beheben kann?
Alles anzeigenpi@hbridge2:~ $ sudo tail -f /var/log/syslog Apr 23 22:58:15 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:15 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:15 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:15 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:26 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart. Apr 23 22:58:26 hbridge2 systemd[1]: Stopping Node.js HomeKit Server... Apr 23 22:58:26 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:26 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:26 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:26 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:36 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart. Apr 23 22:58:36 hbridge2 systemd[1]: Stopping Node.js HomeKit Server... Apr 23 22:58:36 hbridge2 systemd[1]: Starting Node.js HomeKit Server... Apr 23 22:58:36 hbridge2 systemd[1]: Started Node.js HomeKit Server. Apr 23 22:58:36 hbridge2 systemd[1]: homebridge.service: main process exited, code=killed, status=11/SEGV Apr 23 22:58:36 hbridge2 systemd[1]: Unit homebridge.service entered failed state. Apr 23 22:58:46 hbridge2 systemd[1]: homebridge.service holdoff time over, scheduling restart.
das geht dann immer so weiter. Liegt es eventuell daran, dass es ein Pi 1 ist? Würde das 4.4 image vielleicht etwas ändern?
Das LOG sagt ja garnichts aus.
Kann ich nicht sagen, habe nur pi2 und pi3.
Einfach mal testen.
evtl. mal den Dienst stoppen
und manuell einfach "homebridge" eingeben und log beobachten, ob da was zu sehen ist.
kurze Frage habe gerade homebridge-roomba installiert. Es soll lt. Anleitung npm run getrobotpwd in dem Installationsverzeichnis von homebridge-roomba ausgeführt werden. Aber ich bin scheinbar gerade Bild. Wo finde ich das homebridge-roomba Verzeichnis ? (Nutze das Image hier aus dem Thread)
aus dem Kopf in
Hallo zusammen, ich versuche mich gerade eben am ersten Beitrag.
Nachdem ich die Vorbereitungen gemcht haben und mich per ssh auf das Pi aufschalten möchte gibt es ein Problem.
in der Beschreibung steht:
Anmeldung per SSH mit User: pi und dessen Standart Password möglich.
Wie lautet denn das Standart Password?
Danke für die Hilfe
Ja genau das meine ich ja, wie lautet das Standart Password vom User pi?
Versuch es mal mit „raspberry“
vielen Dank hat geklappt . DANKE
Das aufsetzen klappte nun.
Nun habe ich das Problem, dass ich das Plugin "homebridge-fritz" nicht installieren kann bzw. es Fehlermeldung gibt bei der Installation.
Codepi@hbridge2:~ $ sudo npm i homebridge-fritz -g npm ERR! code 128 npm ERR! Command failed: /usr/bin/git submodule update -q --init --recursive npm ERR! fatal: Could not change back to '/root/.npm/_cacache/tmp/git-clone-ea204957': Keine Berechtigung npm ERR! npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-09-12T05_16_52_399Z-debug.log
Ich weiß leider nichts damit anzufangen bzw. was ich nun machen soll.
Kann jemand helfen?
Klappt immmer noch nicht , es erscheint folgendes nach Installation des Plugin
Alles anzeigen-- Logs begin at Thu 2016-11-03 18:16:42 CET. -- Sep 12 12:46:41 hbridge2 homebridge[1319]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10) Sep 12 12:46:41 hbridge2 homebridge[1319]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) Sep 12 12:46:41 hbridge2 homebridge[1319]: at Module._compile (module.js:635:30) Sep 12 12:46:41 hbridge2 homebridge[1319]: at Object.Module._extensions..js (module.js:646:10) Sep 12 12:46:41 hbridge2 homebridge[1319]: at Module.load (module.js:554:32) Sep 12 12:46:41 hbridge2 homebridge[1319]: at tryModuleLoad (module.js:497:12) Sep 12 12:46:41 hbridge2 homebridge[1319]: at Function.Module._load (module.js:489:3) Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Unit entered failed state. Sep 12 12:46:41 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'. Sep 12 12:46:51 hbridge2 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart. Sep 12 12:46:51 hbridge2 systemd[1]: Stopped Node.js HomeKit Server. Sep 12 12:46:51 hbridge2 systemd[1]: Started Node.js HomeKit Server. Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:46:52 hbridge2 homebridge[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> Sep 12 12:46:52 hbridge2 node[1356]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:53] ==================== Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] ERROR LOADING PLUGIN homebridge-fritz: Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Error: Plugin /usr/local/lib/node_modules/homebridge-fritz requires a HomeBridge version of ^0.4.38 which does not satisfy the current HomeBridge version of 0.4.33. You may need to upgrade your installation of HomeBridge. Sep 12 12:46:54 hbridge2 homebridge[1356]: at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:56:11) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:142:14) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Array.forEach (<anonymous>) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:138:22) Sep 12 12:46:54 hbridge2 homebridge[1356]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:24) Sep 12 12:46:54 hbridge2 homebridge[1356]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module._compile (module.js:635:30) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.Module._extensions..js (module.js:646:10) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module.load (module.js:554:32) Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] ==================== Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] No plugins found. See the README for information on installing plugins. Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Loaded config.json with 0 accessories and 1 platforms. Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] --- Sep 12 12:46:54 hbridge2 homebridge[1356]: [2018-9-12 12:46:54] Loading 1 platforms... Sep 12 12:46:54 hbridge2 homebridge[1356]: /usr/local/lib/node_modules/homebridge/lib/api.js:122 Sep 12 12:46:54 hbridge2 homebridge[1356]: throw new Error("The requested platform '" + name + "' was not registered by any plugin."); Sep 12 12:46:54 hbridge2 homebridge[1356]: ^ Sep 12 12:46:54 hbridge2 homebridge[1356]: Error: The requested platform 'Fritz!Box' was not registered by any plugin. Sep 12 12:46:54 hbridge2 homebridge[1356]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:294:45) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:85:36) Sep 12 12:46:54 hbridge2 homebridge[1356]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module._compile (module.js:635:30) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Object.Module._extensions..js (module.js:646:10) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Module.load (module.js:554:32) Sep 12 12:46:54 hbridge2 homebridge[1356]: at tryModuleLoad (module.js:497:12) Sep 12 12:46:54 hbridge2 homebridge[1356]: at Function.Module._load (module.js:489:3) Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Unit entered failed state. Sep 12 12:46:54 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'. Sep 12 12:47:04 hbridge2 systemd[1]: homebridge.service: Service hold-off time over, scheduling restart. Sep 12 12:47:04 hbridge2 systemd[1]: Stopped Node.js HomeKit Server. Sep 12 12:47:04 hbridge2 systemd[1]: Started Node.js HomeKit Server. ^YSep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:47:04 hbridge2 homebridge[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi. Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node> Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** The program 'node' called 'DNSServiceRegister()' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Avahi. Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** Please fix your application to use the native API of Avahi! Sep 12 12:47:04 hbridge2 node[1381]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node&f=DNSServiceRegister> ^XSep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ==================== Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ERROR LOADING PLUGIN homebridge-fritz: Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Error: Plugin /usr/local/lib/node_modules/homebridge-fritz requires a HomeBridge version of ^0.4.38 which does not satisfy the current HomeBridge version of 0.4.33. You may need to upgrade your installation of HomeBridge. Sep 12 12:47:06 hbridge2 homebridge[1381]: at Plugin.load (/usr/local/lib/node_modules/homebridge/lib/plugin.js:56:11) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server.<anonymous> (/usr/local/lib/node_modules/homebridge/lib/server.js:142:14) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Array.forEach (<anonymous>) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server._loadPlugins (/usr/local/lib/node_modules/homebridge/lib/server.js:138:22) Sep 12 12:47:06 hbridge2 homebridge[1381]: at new Server (/usr/local/lib/node_modules/homebridge/lib/server.js:56:24) Sep 12 12:47:06 hbridge2 homebridge[1381]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:26:16) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module._compile (module.js:635:30) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.Module._extensions..js (module.js:646:10) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module.load (module.js:554:32) Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] ==================== Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] No plugins found. See the README for information on installing plugins. Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Loaded config.json with 0 accessories and 1 platforms. Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] --- Sep 12 12:47:06 hbridge2 homebridge[1381]: [2018-9-12 12:47:06] Loading 1 platforms... Sep 12 12:47:06 hbridge2 homebridge[1381]: /usr/local/lib/node_modules/homebridge/lib/api.js:122 Sep 12 12:47:06 hbridge2 homebridge[1381]: throw new Error("The requested platform '" + name + "' was not registered by any plugin."); Sep 12 12:47:06 hbridge2 homebridge[1381]: ^ Sep 12 12:47:06 hbridge2 homebridge[1381]: Error: The requested platform 'Fritz!Box' was not registered by any plugin. Sep 12 12:47:06 hbridge2 homebridge[1381]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:122:13) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:294:45) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:85:36) Sep 12 12:47:06 hbridge2 homebridge[1381]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module._compile (module.js:635:30) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Object.Module._extensions..js (module.js:646:10) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Module.load (module.js:554:32) Sep 12 12:47:06 hbridge2 homebridge[1381]: at tryModuleLoad (module.js:497:12) Sep 12 12:47:06 hbridge2 homebridge[1381]: at Function.Module._load (module.js:489:3) Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Unit entered failed state. Sep 12 12:47:06 hbridge2 systemd[1]: homebridge.service: Failed with result 'exit-code'.
Keiner eine Idee?
Hey ihr lieben,
hat zufällig jemand hier ein funktionierendes Image bei dem man nicht mehr viel bis wenig machen muss?
Ich habe nun schon so einiges ausprobiert und das ganze beendet sich immer wieder einfach. Es gibt keine Errors. Homebridge beendet sich einfach nur.
Würde mich freuen wenn mir jemand behilflich sein kann.
Ich benutze aktuell auch nur die Harmony und Hue Plugins. Hue auch nur wegen den Osram Smart+ Steckern
Oder gibt es eine Möglichkeit, dass ganze so zu Programmieren, dass Homebridge automatisch wieder startet wenn es beendet wird.
Bin für jede Hilfe dankbar.
