Homebridge gestoppt
  • Hallo zusammen, seit drei Tagen bekomme ich die Homebridge nicht mehr zum laufen. Ich finde keinen Fehler, sie ist einfach gestoppt. kann mir da jemand einen Tipp geben? Läuft auf Raspi 3. Parallel läuft noch iobroker und zwaveme auf dem Gerät. hat die letzten 1 1/2 Jahre funktioniert.
    Hier der letzte Log:
    Stopping Node.js HomeKit Server...
    [4/12/2020, 09:42:15] Got SIGTERM, shutting down Homebridge...
    homebridge.service: Succeeded.
    Stopped Node.js HomeKit Server.
    homebridge.service: Found left-over process 1423 (homebridge-conf) in control group while starting unit. Ignoring.
    This usually indicates unclean termination of a previous run, or service implementation deficiencies.
    homebridge.service: Found left-over process 3354 (sh) in control group while starting unit. Ignoring.
    homebridge.service: Found left-over process 3355 (sudo) in control group while starting unit. Ignoring.
    homebridge.service: Found left-over process 3360 (systemctl) in control group while starting unit. Ignoring.
    Started Node.js HomeKit Server.
    pam_unix(sudo:session): session closed for user root
    [4/12/2020, 09:42:22] Loaded config.json with 1 accessories and 2 platforms.
    [4/12/2020, 09:42:22] ---
    [4/12/2020, 09:42:22] Loaded plugin: homebridge-config-ui-x
    [4/12/2020, 09:42:22] Registering platform 'homebridge-config-ui-x.config'
    [4/12/2020, 09:42:22] Loaded plugin: homebridge-sonos
    [4/12/2020, 09:42:22] Registering accessory 'homebridge-sonos.Sonos'
    [4/12/2020, 09:42:23] Loaded plugin: homebridge-zway
    [4/12/2020, 09:42:23] Registering accessory 'homebridge-zway.ZWayServer'
    [4/12/2020, 09:42:23] Registering platform 'homebridge-zway.ZWayServer'
    [4/12/2020, 09:42:23] ---
    [4/12/2020, 09:42:23] Loading 2 platforms...
    [4/12/2020, 09:42:23] [Config] Initializing config platform...
    [4/12/2020, 09:42:23] [Config] Spawning homebridge-config-ui-x with PID 3384
    [4/12/2020, 09:42:23] [ZWayServer] Initializing ZWayServer platform...
    [4/12/2020, 09:42:23] Loading 1 accessories...
    [4/12/2020, 09:42:23] [One] Initializing Sonos accessory...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Schalter Kamin'...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Subwoofer'...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Lampe Sofa'...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Jalousie R'...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Jalousie L'...
    [4/12/2020, 09:42:23] [ZWayServer] Initializing platform accessory 'Jalousie R W'...
    [4/12/2020, 09:42:23] [One] Found a playable device at 192.168.178.51 for room 'Küche'
    [4/12/2020, 09:42:27] [Config] Homebridge Config UI X v4.14.0 is listening on :: port 8080
    homebridge : TTY=unknown ; PWD=/ ; USER=root ; COMMAND=/bin/kill -9 3498
    pam_unix(sudo:session): session opened for user root by (uid=0)
    Habe NPM und Node mal die Vorgängerversionen installiert, leider keine Änderung.
    Ich bedanke mich schon mal im Voraus
    Grüße Andreas
  • Versuch mal uebers Terminal direkt:
    sudo systemctl stop homebridge
    sudo systemctl restart homebridge
    sudo journalctl -fau homebridge
    und dann poste mal das log, sofern die homebridge danach immer noch nicht laeuft!
  • Sieht aus, als würde der Startvorgang nicht beendet, sondern irgendwo hängen bleiben. Möglicherweise geht das Sonos-Plugin nicht richtig. Vielleicht mal aus der Konfiguration nehmen und sehen, ob dann wenigstens der Rest geht.
    Den Bildschirmausdruck bitte beim nächsten Mal im Drogeriemarkt auf Postergröße ausdrucken lassen und per Briefpost an die einzelnen Forenteilnehmer versenden. Oder um es präziser zu sagen: das Log wie oben mit copy&paste hier einzufügen, war eine gute und richtige Idee und danke dafür, mit einem Foto von einem Logauszug kann keiner was anfangen. So wenig wie mit dem Poster.
  • Guten Morgen zusammen,
    danke für den Hinweis mit dem Poster :D. Werde ich in Zukunft berücksichtigen.
    Hier der Log, Habe die Sonos auch mal rausgenommen, ändert sich aber nix.
    pi@raspberrypi:~ $ sudo systemctl stop homebridge
    pi@raspberrypi:~ $ sudo systemctl restart homebridge
    pi@raspberrypi:~ $ sudo journalctl -fau homebridge
    -- Logs begin at Sat 2020-04-11 10:03:27 CEST. --
    Apr 13 09:09:33 raspberrypi homebridge[29819]: [4/13/2020, 09:09:33] [One] Initializing Sonos accessory...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Schalter Kamin'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Subwoofer'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Lampe Sofa'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Jalousie R'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Jalousie L'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [ZWayServer] Initializing platform accessory 'Jalousie R W'...
    Apr 13 09:09:34 raspberrypi homebridge[29819]: [4/13/2020, 09:09:34] [One] Found a playable device at 192.168.178.51 for room 'Küche'
    Apr 13 09:09:38 raspberrypi homebridge[29819]: [4/13/2020, 09:09:38] [Config] Homebridge Config UI X v4.14.0 is listening on :: port 8080
  • Es hatte mit einer Jalousieeinstellung zu tun. Da waren zwei Optionen gleilchzeitig aktiv. Nun läuft es wieder. Danke für die Tipps und noch ein schönes Restosterwochenende. Poster von der laufenden HB verschicke ich morgen ;)
    Grüße Andreas
  • Poster von der laufenden HB verschicke ich morgen ;)
    :D
  • moinsen,
    habe jetzt das selbe Problem, nachdem ich Node geupdatet habe?! Kann ich das irgendwie rückgängig machen? Die Homerbridge läuft an sich im Webinterface ganz Normal, auch über das Webinterface aber in der Homeapp sind alle Geräte auf nicht antworten........... weiß jemand rat? ;)
    Feb 13 16:20:53 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
    Feb 13 16:20:53 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
    Feb 13 16:20:53 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
    Feb 13 16:20:53 raspberrypi systemd[1]: homebridge.service: Found left-over process 858 (node) in control group while starting unit. Ignoring.
    Feb 13 16:20:53 raspberrypi systemd[1]: This usually indicates unclean termination of a previous run, or service implementation deficiencies.
    Feb 13 16:20:53 raspberrypi systemd[1]: Started Node.js HomeKit Server.
    Feb 13 16:20:56 raspberrypi homebridge[925]: [13/02/2021, 16:20:55] Loaded config.json with 2 accessories and 6 platforms.
    Feb 13 16:20:56 raspberrypi homebridge[925]: [13/02/2021, 16:20:56] ---
    Feb 13 16:20:58 raspberrypi homebridge[925]: [13/02/2021, 16:20:58] Loaded plugin: [email protected]
    Feb 13 16:20:58 raspberrypi homebridge[925]: [13/02/2021, 16:20:58] Registering platform 'homebridge-config-ui-x.config'
    Feb 13 16:20:58 raspberrypi homebridge[925]: [13/02/2021, 16:20:58] ---
    Feb 13 16:20:58 raspberrypi homebridge[925]: [13/02/2021, 16:20:58] Registering platform 'homebridge-delayed-switches.DelayedSwitches'
    Feb 13 16:20:58 raspberrypi homebridge[925]: [13/02/2021, 16:20:58] Registering accessory 'homebridge-dummy.DummySwitch'
    Feb 13 16:20:59 raspberrypi homebridge[925]: [13/02/2021, 16:20:59] Loaded plugin: [email protected]
    Feb 13 16:20:59 raspberrypi homebridge[925]: [13/02/2021, 16:20:59] Registering platform 'homebridge-eveatmo.eveatmo'
    Feb 13 16:20:59 raspberrypi homebridge[925]: [13/02/2021, 16:20:59] ---
    Feb 13 16:21:00 raspberrypi homebridge[925]: [13/02/2021, 16:21:00] Loaded plugin: [email protected]
    Feb 13 16:21:00 raspberrypi homebridge[925]: [13/02/2021, 16:21:00] Registering platform 'homebridge-ifttt.IFTTT'
    Feb 13 16:21:00 raspberrypi homebridge[925]: [13/02/2021, 16:21:00] ---
    Feb 13 16:21:01 raspberrypi homebridge[925]: [13/02/2021, 16:21:01] Loaded plugin: [email protected]
    Feb 13 16:21:01 raspberrypi homebridge[925]: [13/02/2021, 16:21:01] Registering platform 'homebridge-moodo.MoodoPlatform'
    Feb 13 16:21:01 raspberrypi homebridge[925]: [13/02/2021, 16:21:01] ---
    Feb 13 16:21:02 raspberrypi homebridge[925]: [13/02/2021, 16:21:02] Loaded plugin: [email protected]
    Feb 13 16:21:02 raspberrypi homebridge[925]: [13/02/2021, 16:21:02] Registering platform 'homebridge-nuki.NukiPlatform'
    Feb 13 16:21:02 raspberrypi homebridge[925]: [13/02/2021, 16:21:02] ---
    Feb 13 16:21:03 raspberrypi homebridge[925]: [13/02/2021, 16:21:03] Loaded plugin: [email protected]
    Feb 13 16:21:03 raspberrypi homebridge[925]: [13/02/2021, 16:21:03] Registering platform 'homebridge-rademacher-homepilot.RademacherHomePilot'
    Feb 13 16:21:03 raspberrypi homebridge[925]: [13/02/2021, 16:21:03] ---
    Feb 13 16:21:03 raspberrypi homebridge[925]: [13/02/2021, 16:21:03] Loading 6 platforms...
    habe den Pi auch schon mehrfach neugestartet.....aber hilft auch nichts
  • weiß jemand rat?
    Ja. Du könntest mal das ganze Log posten und nicht nur den Anfang. Von Started Node.js HomeKit Server bis zum Ende.
    Bitte beachten: das ist kein Windows-Computer.
  • Und dann bitte das Log mit der Code-Funktion posten.
    Oben die <\> benutzen und dann das Log einfügen bitte!
  • danke euch erstmal!
    hier das ganze Logs
    wie gesagt, über das WebInterface ist die Homebridge normal erreichbar über Home leider nicht mehr
  • hab jetzt mal das Moodo Plugin runtergeschmissen und jetzt kam das :
    Einmal editiert, zuletzt von phil1988 ()
  • In beiden Fällen sehe ich eine funktionierende Homebridge: Homebridge is running on port 51826.
  • Wenn die Homebridge läuft wäre mein nächster Versuch, den Hub (ATV, HomePod...) neu zu starten. Danach viellicht auch mal den Router selber.
  • So nachdem ich jetzt Plugin für Plugin mal auf die andere Bridge geschoben hab, hab ich festgestellt dass es am Eveatmo Plugin liegt. Die Püppi an sich funktioniert noch aber es sorgt dafür dass die Geräte nicht mehr an steuerbar sind in der Home App
    Wird ein toller Sonntag wieder alle Automation neu zu machen😀😀😀
  • soooo nach einem Tag voller Verzweiflung und dauerndem Fluchen läuft es jetzt wieder. Hab mir gedacht ich schreibe mal rein falls es irgendwann jemandem genauso geht.
    Erstmal hatte ich rausgefunden das es am Eveatmo Plugin liegt.Ich habe sowohl das Innenmodul als auch Wind und Regenmesser. In der Zeit hatte ich die Bridge schon neu aufgesetzt. Plugin eingebunden und zack ging nichts. Dann kam die ganze Zeit UUID Fehler und ich konnte mir nicht erklären woher das kommt, da die Bridge ja komplett neu aufgesetzt war. Habe gedacht es liegt vielleicht am Dev Account. Den neu gemacht, immer noch nicht. Anschließend mal in der Netatmo App geschaut ob es vielleicht eine neue Firmware gibt oder so. Da habe ich festgestellt, das mein Modul keine WLAN Verbindung mehr. Voller Vorfreude die neu eingerichtet und siehe da NICHTS. Immer noch der selbe Fehler. Ich konnte es mir nicht erklären. Letzter Schritt einfach Netatmo mal komplett neu machen und alle Module rausschmeissen. Siehe da das hat funktioniert, nachdem ich jetzt nacheinander alle Module nochmal reingesetzt hab, hats es wieder funktioniert..........kein Plan wie sowas passieren kann.
    Viel Stress aber jetzt Genugtuung :D
