ich versuche grade auch den Sensor zum laufen zu bringen und habe schon Schwierigkeiten beim installieren vom Bluetooth Modul:
pi@raspberrypi:~ $ sudo apt-get install bluetooth bluez libbluetooth-dev libudev-dev
Reading package lists... Done
Building dependency tree
Reading state information... Done
bluez is already the newest version (5.43-2+rpt2+deb9u2).
bluez set to manually installed.
Suggested packages:
bluez-cups bluez-obexd
The following NEW packages will be installed:
bluetooth libbluetooth-dev libbluetooth3
libudev-dev
0 upgraded, 4 newly installed, 0 to remove and 0 not upgraded.
Need to get 91.9 kB/407 kB of archives.
After this operation, 1,000 kB of additional disk space will be used.
Err:1
http://raspbian.raspberrypi.org/raspbian
stretch/main armhf libudev-dev armhf 232-25+deb9u9
404 Not Found [IP: 2a00:1098:0:80:1000:75:0:3 80]
E: Failed to fetch
http://raspbian.raspberrypi.or…v_232-25+deb9u9_armhf.deb
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
Hat jemand eine Idee und kann mir weiterhelfen.
Ich bin leider blutiger Linux Anfänger.
Lg
