hey zusammen,
Ich kann meine Homebridge nicht mehr erreichen.
Diese startet nicht mehr und ich bekomme folgenden Fehler im
Mar 04 00:39:42 raspberrypi homebridge[14951]: [3/4/2020, 12:39:42 AM] [Config] Homebridge Config UI X v4.11.0 is listening on :: port
Kann mir jemand helfen?
Scheint irgend ein Problem mit dem Port 8080 zu sein
hier der start log
-- Logs begin at Wed 2020-03-04 00:42:58 CET. --
Mar 04 01:00:01 raspberrypi homebridge[3208]: [3/4/2020, 01:00:01] [Config] cd /usr/local/lib/node_modules/homebridge-config-ui-x
Mar 04 01:00:01 raspberrypi homebridge[3208]: [3/4/2020, 01:00:01] [Config] sudo npm rebuild --unsafe-perm
Mar 04 01:00:02 raspberrypi homebridge[3330]: [3/4/2020, 01:00:02] Loaded config.json with 6 accessories and 7 platforms.
Mar 04 01:00:02 raspberrypi homebridge[3330]: [3/4/2020, 01:00:02] ---
Mar 04 01:00:04 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
Mar 04 01:00:04 raspberrypi systemd[1]: homebridge.service: Main process exited, code=killed, status=15/TERM
Mar 04 01:00:04 raspberrypi systemd[1]: homebridge.service: Succeeded.
Mar 04 01:00:04 raspberrypi systemd[1]: Stopped Node.js HomeKit Server.
Mar 04 01:00:04 raspberrypi systemd[1]: Started Node.js HomeKit Server.
Mar 04 01:00:06 raspberrypi homebridge[3371]: [3/4/2020, 01:00:06] Loaded config.json with 6 accessories and 7 platforms.
Mar 04 01:00:06 raspberrypi homebridge[3371]: [3/4/2020, 01:00:06] ---
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Loaded plugin: homebridge-alexa
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Registering platform 'homebridge-alexa.Alexa'
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] ---
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Loaded plugin: homebridge-config-ui-x
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Registering platform 'homebridge-config-ui-x.config'
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Loaded plugin: homebridge-dummy
Mar 04 01:00:07 raspberrypi homebridge[3371]: [3/4/2020, 01:00:07] Registering accessory 'homebridge-dummy.DummySwitch'
Mar 04 01:00:09 raspberrypi homebridge[3371]: [3/4/2020, 01:00:09] Loaded plugin: homebridge-hue
Mar 04 01:00:09 raspberrypi homebridge[3371]: [3/4/2020, 01:00:09] Registering platform 'homebridge-hue.Hue'
Mar 04 01:00:09 raspberrypi homebridge[3371]: [3/4/2020, 01:00:09] ---
Mar 04 01:00:09 raspberrypi homebridge[3371]: [3/4/2020, 01:00:09] Loaded plugin: homebridge-mobilealerts
Mar 04 01:00:09 raspberrypi homebridge[3371]: homebridge API Version: 2.4
Mar 04 01:00:09 raspberrypi homebridge[3371]: [3/4/2020, 01:00:09] Registering platform 'homebridge-mobilealerts.MobileAlerts'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Loaded plugin: homebridge-people
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering platform 'homebridge-people.People'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering accessory 'homebridge-people.PeopleAccessory'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering accessory 'homebridge-people.PeopleAllAccessory'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] ---
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Loaded plugin: homebridge-pi
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering accessory 'homebridge-pi.PiTemperature'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Loaded plugin: homebridge-samsung-tizen
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering platform 'homebridge-samsung-tizen.SamsungTizen'
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Loaded plugin: homebridge-tuya-lan
Mar 04 01:00:10 raspberrypi homebridge[3371]: [3/4/2020, 01:00:10] Registering platform 'homebridge-tuya-lan.TuyaLan'
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] Loaded plugin: homebridge-xiaomi-roborock-vacuum
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] Registering accessory 'homebridge-xiaomi-roborock-vacuum.XiaomiRoborockVacuum'
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] ---
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] Loading 7 platforms...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing People platform...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'Martin'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'Ramona'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'Sabine'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'Uwe'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'Anyone'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] Initializing platform accessory 'No One'...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [People] WebHook: Started server on port '51828'.
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [Config] Initializing config platform...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [Config] Spawning homebridge-config-ui-x with PID 3406
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [Hue] Initializing Hue platform...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [Hue] homebridge-hue v0.11.57, node v12.16.1, homebridge v0.4.52
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [Hue] warning: not using recommended homebridge version v0.4.50
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [MobileAlerts] Initializing MobileAlerts platform...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [MobileAlerts] iPhone-ID was set to 666922332141...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [MobileAlerts] Poling Interval not configured properly! >> Using default of 420s...
Mar 04 01:00:11 raspberrypi homebridge[3371]: [3/4/2020, 01:00:11] [MobileAlerts] Fetching Data...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [SamsungTizen] Initializing SamsungTizen platform...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Alexa] Initializing Alexa platform...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Alexa] homebridge-alexa v0.4.52, node v12.16.1, homebridge v0.4.52
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] Error: The requested platform 'TuyaWebPlatform' was not registered by any plugin.
Mar 04 01:00:12 raspberrypi homebridge[3371]: at API.platform (/usr/local/lib/node_modules/homebridge/lib/api.js:134:13)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:327:45)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:90:36)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:59:10)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge/bin/homebridge:17:22)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Module._compile (internal/modules/cjs/loader.js:1158:30)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Object.Module._extensions..js (internal/modules/cjs/loader.js:1178:10)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Module.load (internal/modules/cjs/loader.js:1002:32)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Function.Module._load (internal/modules/cjs/loader.js:901:14)
Mar 04 01:00:12 raspberrypi homebridge[3371]: at Function.executeUserEntryPoint [as runMain] (internal/modules/run_main.js:74:12)
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] Got SIGTERM, shutting down Homebridge...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Philips hue: Philips BSB002 bridge v1937045000, api v1.36.0
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Philips hue: 4 accessories
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] masked debug info dumped to /var/homebridge/homebridge-hue.json.gz
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Initializing platform accessory 'Philips hue'...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Philips hue: 2 services
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Initializing platform accessory 'Plug Vitrine'...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Initializing platform accessory 'Glasherz'...
Mar 04 01:00:12 raspberrypi homebridge[3371]: [3/4/2020, 01:00:12] [Hue] Initializing platform accessory 'Sauna'...
Mar 04 01:00:16 raspberrypi homebridge[3371]: [3/4/2020, 01:00:16] [Config] Homebridge Config UI X v4.11.0 is listening on :: port 8080
Mar 04 01:00:17 raspberrypi systemd[1]: homebridge.service: Main process exited, code=exited, status=143/n/a
Mar 04 01:00:17 raspberrypi systemd[1]: homebridge.service: Failed with result 'exit-code'.
Mar 04 01:00:27 raspberrypi systemd[1]: homebridge.service: Service RestartSec=10s expired, scheduling restart.
Mar 04 01:00:27 raspberrypi systemd[1]: homebridge.service: Scheduled restart job, restart counter is at 1.
