homebridge-calendar ( Kalender Trigger)
Für diejenigen, welche auf einen Offset warten: Die neueste Version auf GitHub bietet euch die Funktion. Wäre schön, wenn jemand das vorab testen könnte - ich plane die Version am Wochenende zu veröffentlichen.
Config sollte klar sein
Die log
sudo cat /var/log/homebridge.log
Ich werde Testen
Alles anzeigen[2018-2-26 21:27:29] Homebridge is running on port 51826. [2018-2-26 21:29:59] [HttpWebHooks] Getting current state for 'pushbutton5'... [2018-2-26 21:29:59] [HttpWebHooks] Getting current state for 'pushbutton6'... [2018-2-26 21:30:02] [HttpWebHooks] Getting current state for 'pushbutton4'... [2018-2-26 21:30:04] [CallMonitor] Returning current incoming call status: s=0 [2018-2-26 21:30:04] [CallMonitor] Returning current outgoing call status: s=0 [2018-2-26 21:30:04] [HttpWebHooks] Getting current state for 'pushbutton7'... [2018-2-26 21:30:06] [HttpWebHooks] Getting current state for 'pushbutton2'... [2018-2-26 21:30:06] [HttpWebHooks] Getting current state for 'pushbutton3'... [2018-2-26 21:30:06] [Nuki] Send request to Nuki bridge 'http://192.168.178.35:8080' on '/lockState' with '{"token":"GqWv5L","nukiId":"106975545"}'. [2018-2-26 21:30:08] [Nuki] Request to Nuki bridge 'http://192.168.178.35:8080' finished with status code '200' and body '{"state": 3, "stateName": "unlocked", "batteryCritical": false, "success": true}'. null [2018-2-26 21:30:08] [Nuki] Lock state is isLocked = 'false' (Nuki state '3' ) with battery critical = 'false' [2018-2-26 21:30:08] [Nuki] Lock state is isLocked = 'false' (Nuki state '3' ) with battery critical = 'false' [2018-2-26 21:30:08] [Nuki] Lock state is isLocked = 'false' (Nuki state '3' ) with battery critical = 'false' [2018-2-26 21:30:08] [Nuki] Lock state is isLocked = 'false' (Nuki state '3' ) with battery critical = 'false' [2018-2-26 21:30:10] [HttpWebHooks] Getting current state for 'pushbutton8'... [2018-2-26 21:30:48] [Maik Switch] Setting switch to true [2018-2-26 21:30:48] [Aniko Switch] Setting switch to true [2018-2-26 21:31:50] [Maik Switch] Setting switch to true [2018-2-26 21:31:50] [Aniko Switch] Setting switch to true [2018-2-26 21:32:24] [Calendar] Updating calendar Abfall [2018-2-26 21:32:26] [Calendar] Setting Abfall to true [2018-2-26 21:32:26] [Calendar] Setting Restabfall to true [2018-2-26 21:32:26] [Calendar] Pushing calendar sensor 'Abfall' state 1 - value 1 [2018-2-26 21:32:26] [Calendar] Pushing calendar sensor 'Restabfall' state 1 - value 1 [2018-2-26 21:32:26] [Calendar] Pushing calendar sensor 'Gelber Sack' state 0 - value 0 [2018-2-26 21:32:31] [CallMonitor] Returning current incoming call status: s=0 [2018-2-26 21:32:31] [CallMonitor] Returning current outgoing call status: s=0 [2018-2-26 21:32:31] [HttpWebHooks] Getting current state for 'pushbutton5'... [2018-2-26 21:32:31] [HttpWebHooks] Getting current state for 'pushbutton7'... [2018-2-26 21:35:50] [CallMonitor] Returning current incoming call status: s=0 [2018-2-26 21:35:50] [CallMonitor] Returning current outgoing call status: s=0 [2018-2-26 21:35:50] [HttpWebHooks] Getting current state for 'pushbutton5'... [2018-2-26 21:35:50] [HttpWebHooks] Getting current state for 'pushbutton7'... [2018-2-26 21:35:52] [HttpWebHooks] Getting current state for 'pushbutton4'... [2018-2-26 21:35:52] [HttpWebHooks] Getting current state for 'pushbutton5'... [2018-2-26 21:35:54] [HttpWebHooks] Getting current state for 'pushbutton5'... [2018-2-26 21:35:54] [HttpWebHooks] Getting current state for 'pushbutton6'... [2018-2-26 21:37:25] [Hue] Maik : add history entry {"time":1519677445,"status":1} [2018-2-26 21:37:25] [Hue] XFDAnybodyHome: add history entry {"time":1519677445,"status":1} [2018-2-26 21:37:25] [Hue] Aniko : add history entry {"time":1519677445,"status":1} [2018-2-26 21:37:26] [Calendar] Updating calendar Abfall [2018-2-26 21:37:26] [Calendar] Pushing calendar sensor 'Abfall' state 0 - value 0 [2018-2-26 21:37:26] [Calendar] Pushing calendar sensor 'Restabfall' state 0 - value 0 [2018-2-26 21:37:26] [Calendar] Pushing calendar sensor 'Gelber Sack' state 0 - value 0 [2018-2-26 21:37:26] [Calendar] No events to schedule. [2018-2-26 21:39:36] [Maik Switch] Setting switch to true [2018-2-26 21:39:36] [Aniko Switch] Setting switch to true
Alles anzeigen{ "platform": "Calendar", "calendars": [ { "name": "Abfall", "url": "webcal://p72-calendars.icloud.com/published/2/jsK2-zF31pOYGhG76f3yql4a0elKfTLywqObz_he9Em9xY0kf9ayXxxxxxxxxxn7NXh_PRfoOBpOl4yD6iP_c0vfUy-p9_L77k6w6m-P_3js", "pollingInterval": 5, "sensors": [ "Restabfall", "Gelber Sack" ] } ] },
Ich komme vermutlich morgen Abend zum testen und habe am Donnerstag schon Abfalltermine, welchex dann am Mittwoch Abend auslösen sollten.
Gibt es einen maximalen Wert für den Offset? Ich meine z.b. kann auch 30 h angegeben werden?
Der Offset bezieht sich auf den gesamten Kalender, oder? Würde mir genügen.....
Vielen Dank noch für die Umsetzung.
Irgendwie hängt es mit dem Abfrageintervall zusammen. Manchmal funktioniert die Abfrage wohl nicht richtig und dann ist der Schalter für 5 Minuten aus bis die nächste Abfrage kommt. Hat vielleicht noch jemand das Problem?
Ich habe die Anleitung zum Plugin so verstanden das nur der Anfang des Kalenders mit der config übereinstimmen muss. Oder muss es doch exakt zusammen passen?
Funktioniert super! Auch mit mehreren Terminen. Schließt dann auch der Sensor wieder mit dem Eingestellen Offset früher oder ist dies immer noch die Endzeit des Termins?
Es wird nur die Anfangszeit vorgezogen. Die Endzeit bleibt, daher der Schalter ist länger Ein: Offsetdauer + Termindauer.
Habe eine Fehlermeldung?
Codesudo npm install github:grover/homebridge-calendar npm ERR! code 128 npm ERR! Command failed: /usr/bin/git clone -q git://github.com/grover/homebridge-calendar.git /root/.npm/_cacache/tmp/git-clone-33aece63 npm ERR! fatal: Konnte führende Verzeichnisse von '/root/.npm/_cacache/tmp/git-clone-33aece63' nicht erstellen.: Keine Berechtigung npm ERR! npm ERR! A complete log of this run can be found in: npm ERR! /root/.npm/_logs/2018-02-26T20_51_04_632Z-debug.log
Uff. Probier mal mit sudo, aber wahrscheinlich ist deine node installation kaputt.
Ich habe am Wochenende auch lernen müssen das npm und sudo nicht gut miteinander können.
Benutzerrechte Zerschossen oder wieso?
Habe ich ja mit sudo gemacht.
könnte da nach install noch das „-g“ gefehlt haben?
Nix mit g mit -g nix geht.
Muss die neuste ppm Version drauf sein?
Derzeit nutze ich die 5.6.0
Node habe ich die 9.4.0
Ich hätte es irgendwie flexibler gefunden, wenn man den Offset per Sensor hätte einstellen können... so muss man u. U. für jeden unterschiedlichen Termin einen eigenen Kalender anlegen, wenn der Offset nur auf einen bestimmten Terminen angewendet werden bzw. für verschiedene Termine unterschiedlich ausfallen soll.
Wobei ich mir ehrlich gesagt auch noch nicht sicher bin, was sinnvoller ist. So wenig Kalender wie möglich mit unterschiedlichen Sensoren für die verschiedenen Terminsarten oder für jede Terminsart einen eigenen Kalender mit den nur die diese Terminsart erforderlichen Sensoren. Ich hatte eigentlich geplant, möglichst nur einen Automationskalender mit unterschiedlichen Sensoren für die jeweiligen Steuerungen zu benutzen, da der aber ohnehin nicht im "normalen" Kalender auftauchen soll, wären die Zeitangaben für den Termin eigentlich egal, also könnte man den benötigten Offset gleich als Startzeit setzen.
Nötig ist der Offset nur dann, wenn der Termin auch im "normalen" Kalender "richtig" angezeigt werden soll. Ich habe bisher deshalb einen Abfallkalender, der auch im normalen Kalender auftaucht, und einen Automationskalender eingepflegt. Im Abfallkalender habe ich natürlich auch mehrere Sensoren für die jeweilige Mülltonne, den Starttermin für den Kalendereintrag habe ich aber gleichmäßig schon auf den Abend vor der Abholung eingestellt, das passt auch für die Steuerung in Homekit. Hier benötige ich kein Offset, da ich auch schon im normalen Kalender vorher erinnert werden möchte. Alternativ könnte man natürlich auch nur den ungefähren Abholzeitraum als Termin eintragen und dann in HK mit dem Offset arbeiten und sich in iOS über die 1. und 2. Erinnerung am Vorabend und am Tag der Abholung morgens erinnern lassen. Puh, ist das kompliziert einen sinnvollen Abfallkalender zu planen
Ich finde den Kalender toll, aber ich benutze ihn nicht für die Müllabfuhr. Bei mir kommen die nämlich einfach klingeln und suchen sich die Tonne dann selber raus. Ich benutze ihn für Fußballspiele von Eintracht Frankfurt. Bei mir soll der Kalender das Radio anmachen, und der Anfangsoffset ist prima, weil ich jetzt das Radio fünf Minuten vorher einschalten kann. Danke dafür, jetzt isses perfekt für mich.
Tatsächlich fangen Fußballspiele eigentlich nie vor dem geplanten Datum an. Sie enden dafür manchmal später: Nachspielzeit, Verlängerung, das Spiel hat vielleicht später begonnen als geplant oder das Publikum hat in der Halbzeitpause das Stadion abgerissen und es muss jetzt erst ein neues gebaut werden. In meinem Fall wäre also ein Offset nach dem Termin ganz brauchbar, aber um ehrlich zu sein: da das Ende des Termins in keinem Fall absehbar ist, wüsste ich auch keinen Offset, und am Ende läuft es dann genau darauf hinaus, dass ich das Radio wie schon jetzt einfach manuell abstelle.
Wie dem auch sei: ich wollte nur mal eine Kalenderanwendung vorstellen, die sich nicht an Müll orientiert... obwohl... wenn ich an das Spiel gegen Stuttgart denke...
Irgendwie geht so etwas hier leider unter.
Weiß den hier Jemand was das Problem sein könnte?
