  • [email protected]
    If you are updating from a version prior to v2.4.0 then please read the changelog to see what has changed in-between versions.New
    • A doorOpenTimer setting per garage which may be useful if you have more than one garage. See the wiki for more info.
    • [experimental] Support for the Wemo (Holmes) Humidifier.
    • [experimental] Support for Adaptive Lighting for Wemo colour temperature bulbs.
    Improvements/Fixes
    • Plugin will now remove any cached accessories in the ignoreDevices list on Homebridge startup, rather than on device discovery.
    • Fixes for the Wemo Crockpot which sometimes incorrectly displayed the current mode/remaining cooking time.
    • Note, any existing ignoredDevices that are stuck in the Homebridge cache will either need to be discovered once, or manually removed from the Homebridge cache for this so start working properly.
    Hilfreich?
  • node.js 14.15.1 für oznu/docker-homebridge
  • Shelly Firmwareupdate 1.9.0
    Läuft mit HB ohne Probleme bei mir.
  • homebridge-shelly
    0.16.0 • Public • Published 3 hours ago
    Add support for the Shelly Uni
  • [email protected] (2020-11-30)
    Notable Changes
    • The Homebridge UI is now available in 23 different languages!
    Other Changes
    • i18n: Improvements to Japanese language translations (#978)
    Bug Fixes
    • Plugins: Custom plugin user interfaces now work correctly in older browsers that do not support the EventTarget constructor
    • Plugins: Ensure @eaDir folders are removed from the /homebridge/node_modules folder when running with Docker on Synology DSM (#970)
    • Plugins: Attempt to automatically clear the npm cache if a UI update fails (#923)
    • System: Lockdown the systeminformation dependency version (#969)
    Hilfreich?
  • Deconz v2.7.0 Beta
    The Whistle
    Repository: dresden-elektronik/deconz-rest-plugin · Tag: v2.7.0-beta · Commit: c030635 · Released by: manup
    This is a beta release based on v2.6.00 beta version.
    Changes
    • Initial support for LIDL/Silvercrest motion sensor #3736 #3779
    • Merry Christmas with LIDL led stripe #3776
    • Fix Aqara Opple switches not receiving button events #3768 #3780
    • Support for new version of Trust ZYCT-202 (ZLL-NonColorController) #3733
    • Support Benexmart 3 gang switch variant (TS0043) #3724
    • Support Saswell SEA801 new variant (_TZE200_c88teujp) #3730
    • Initial support for LEDVANCE aka Sylvania BR30 and A19 #3721
    • Initial support for Samsung water leak sensor (moisturev4) #3737
    • Initial support for LIDL/SilverCrest contact sensor (TY0203) #3773
    • Restore support for Schlage Connect Smart Deadbolt (B3468) #3677
    • Allow receiving door lock operation completion #3751
    • Improve end-device pairing #3769
    • Improve HTTP accept header parsing of API versions; Reintroduce colorcapabilities in API version v1.1 #3703
    • Fix heating setpoint changeable for all Eurotronic Spirit Zigbee thermostats #3680
    • Avoid fake device creation for TUYA light #3774
    • Enhancements and improvements for Sonoff, Bitron, Develco and others #3732
    • Button maps enhancements #3781
    • Support USB device creation inside Docker when required cgroups permissions are set for the container marthoc/docker-deconz/#298
    • Fix handling ZDP Simple Descriptor NotActive status code.
    Firmware
    Hardware Version
    ConBee II 0x26680700
    RaspBee II 0x26680700
    • Fix end-device management;
    • Fix creation of invalid neighbor table entries on incoming commands;
    • Fix joining loop in deCONZ when certain invalid parameters were set;
    • Raised source routes table size from 32 to 64;
    • Routing table size is 170.
    This firmware update is also recommended for ZHA, zigbee2mqtt and WebThings users.
    In this release it needs to be installed manually as described in the Wiki.
  • [email protected]
    0.1.9 Bugfix:
    • Sensors now return cached value if state and value is not provided in URL (thanks to tritter).
    0.1.8 Bugfix:
    • Stateless switch web hook did not return a response.
    Hilfreich?
  • Tedee Bridge Update
    Bilder
  • [email protected]
    If you are updating from a version prior to v2.5.0 then please read the changelog to see what has changed in-between versions.New
    • This update includes a new custom settings panel for homebridge-config-ui-x users. You will need to be running v4.34.0 or greater of the config-ui plugin. This is a feature I plan to add functionality to over time. The panel includes three sections:
    • Settings: The configuration form that you are used to as before
    • My Devices: Information about your Wemo devices that are in Homebridge
    • Support: Useful links to documentation and support
    Changes
    • Fix for Wemo Maker (Switch usage) where ContactSensorState was being added to Switch by error
    • ignoredDevices list will now be parsed to uppercase and spaces stripped
    • Backend changes to the plugin file/folder structure
    Known Issues
    • The Wemo Heater, Humidifier and CrockPot are still experimental - logging is currently excessive for these devices.
    • Issue #218 - SetTemperature is reset to 16 degrees when turning on the Heater (this is being worked on)
    Hilfreich?
  • [email protected]
    0.1.11 Bugfix:
    • Reduced some more log messages by using debug (thanks to jsiegenthaler).
    0.1.10 New features:
    • You can now set "rejectUnauthorized" to false on each accessory to allow calls via https on using unsecure certificate.
    [email protected]
    All notable changes to this project will be documented in this file.The format is based on Keep a Changelog, and this project adheres to Semantic Versioning.[Unreleased][1.4.4] - 2020-12-06
    Added
    • Added support for the dmaker.fan.p11 (Mi Smart Standing Fan Pro)
    • Added support for the dmaker.fan.p15 (Mi Smart Standing Fan Pro EU)
    Hilfreich?
  • ◯ homebridge-hue 0.12.7 ❯ 0.12.8 https://github.com/ebaauw/homebridge-hue#readme
  • homebridge-hue-v0.12.8
    homebridge-zp-v1.1.2
  • [email protected]
    If you are updating from a version prior to v2.6.0 then please read the changelog to see what has changed in-between versions.Changes
    • disablePlugin option to visible in plugin settings form
    • Hide undefined data in custom-ui
    • Log unique device id of wemo link bulbs on startup
    • makerTypes list serial numbers will now be parsed to uppercase and spaces stripped
    Known Issues
    Hilfreich?
