Node 11.12.0
https://github.com/nicoduj/homebridge-harmony/releases
- [NEW] Act as a dynamic platform
- [BREAKING] skipedIfSameStateActivities -> skippedIfSameStateActivities / addAllActivitiesToSkipedIfSameStateActivitiesList -> addAllActivitiesToSkippedIfSameStateActivitiesList
- [BREAKING] MENU command (inside properties of TV Service) renamed to SETUP and will be mapped to setup function if avaliable (can be ovewridden)
homebridge-config-ui-x v3.10.0
Notable Changes
- Themes: Dark mode and other themes added by @RaymondMouthaan (#236)
- Themes: Make it easier to see that there are three separate links at the bottom of ths status page by adding hover effect (#230)
homebridge-alexa v0.3.5
Ich hab noch die 0.1.72 drauf, bei mir wurden die ganzen Versionen bis zu 0.3.5 garnicht angezeigt... scheint auch ein grosses Update zu sein:
MPORTANT - For existing users, installing an updated version of the plugin after March 22, 2019 will cause Alexa to mark all your existing devices as Offline and create new ones.
You will need to manually remove all existing devices after upgrading and setup and groups or routines again. This would only occur with the first update after this date. I would strongly recommend making note and recording the devices that are in each of your groups and routines prior to updating so you can recreate them again afterwards. I made a large change around the device identifiers between homebridge and Alexa, and this should avoid any further duplicate devices. For reference, I'm using these values to create a unique key for Alexa homebridge name, homebridge username, plugin manufacturer, Service and accessory name. ( homebridge name and username are from the config.json bridge settings.) If you never change these values, Alexa should never discover duplicate devices.
Danke für diese Info. Zum Glück hab ich noch relativ wenig Schalter über die alexa-homebridge drin... ich schaue, dass die Geräte nativ gleich alexa können + homekit oder zumindest über plugin.....
Einzig der Vorwerk Robo und die Mija Nachttischlampen musste ich so „überleiten“.
Ein Tipp: über http://alexa.amazon.com/?tag=hktips-forum-21 könnt ihr alle Alexa-Smarthome-Geräte auf einen Schlag löschen. Das habe ich gerade getan, dann alles neu erkennen lassen und meine zwei Gruppen und zwölf Routinen neu eingerichtet.
[NEW] support for Exposing Home Control buttons #67
[BUG] ReferenceError #110
Many thanks to gitgayhub for Home controls in this release, and especially for his patience testing !Gesendet von iPhone mit Community
Ich bin gerade total abgehängt, was die rasante Entwicklung des plugins anbelangt. Was ist denn jetzt möglich?
Es gibt homebridge 0.4.47. Gibt's dazu wo ein Changelog?
Nicht das ich wüsste, läuft aber, schon seit paar Tagen.
Ich bin auch seit Montag auf der 47er homebridge. Bei mir hat nur die icloud gezickt, homebridge selbst läuft stabil.
Jo, irgendwas wurde umgestellt. Aber nach ner Nacht hatte es sich wieder normalisiert. Aber Recht haste, irgendwas zickte da. Habs dann einfach in Ruhe gelassen.
Das sage ich mir auch jedes Mal, einfach nen Tag warten. Und dann juckt es doch, woran es noch liegen könnte und ich muss ran gehn.....
Und nen Tag später bemerkt man, warten hätte gereicht ???
homebridge-config-ui-x@3.11.0 (2019-04-03)
Notable Changes
Auth: The Basic Authentication option has been depreciated. Users should switch to Form Authentication instead (the default).
Other Changes
Swap to using a prebuilt version of the node-pty package to try and reduce errors during installation
Updated other npm dependencies
Von wegen, mit Update auf Version 3.7 „erheblich erweiterte Auswahl von Symbolen“. ?? Hat man einen Schalter in seinem HomeKit Setup und mit der vorherigen App Version z.B. ein Icon von Stereoanlage, Kühlschrank, Wasserkocher oder ähnlich hinterlegt, wird dieses Icon nun einfach durch die App entfernt, sobald man den Namen ändert und nur ein simples Schalter Icon wird fest vorgegeben. ? Geht gar nicht. Ich hoffe für Eve, dass das nur ein Bug ist und ganz schnell behoben wird.
Totale Enttäuschung, da ich im Gegenteil endlich auf ein Update der App mit noch mehr Auswahl an Icons, zur freien Platzierung für Geräte/Schalter gehofft hatte. ?? Diskussion, gerne -> hier.
