Hallo, meine HB will seit heute Nacht einfach nicht mehr starten.
Kann mir jemand helfen und mit den Fehler was anfangen?
Feb 01 12:12:29 raspberrypi system [1]: Started Homebridge.
Feb 01 12:12:31 raspberrypi hb-service.js [7215]: [01/02/2023, 12:12:31] [HB Super visor] Homebridge Storage Path: /var/homebridge
Feb 01 12:12:31
raspberrypi hb-service.js[7215]: [01/02/2023, 12:12:31] [HB Super
visor] Homebridge Config Path: /var /homebridge/config. json
Feb 01 12:12:31 raspberrypi hb-service.js [7215]: [01/02/2023, 12:12:31] [HB Super visor] Logging to /var/homebridge/homebridge.log
Feb 01 12:12:31 raspberrypi hb-service.js[7215]: node: events: 491
throw er; // Unhandled 'er
ror' event
Feb 01 12:12:31 raspberrypi hb-service. js [7215]:
Feb 01 12:12:31 raspberrypi hb-service.js [7215]: Error: ENOSPC: no space left on device, write
Feb 01 12:12:31 raspberrypi hb-service. js [7215]: Emitted 'error' event on WriteSt ream instance at:
at emitErrorNT (node:interna
1/streams/destroy: 151:8)
at emitErrorCloseNT (node:in
ternal/streams/destroy: 116:3)
at process.processTicksAndRe
jections (node: internal/process/task_queues: 82:21) {
errno: -28,
Feb 01 12:12:31
code: 'ENOSPC',
syscall: 'write'
Feb 01 12:12:31 raspberrypi hb-service.js [7215]: Node.js v18.13.0
Feb 01 12:12:31 raspberrypi system [1]: homebridge.service: Main process exited, code=exited, status=1/FAILURE
Feb 01 12:12:31 raspberrypi systemd[1]: homebridge.service: Failed with result 'e xit-code'
Feb 01 12:12:34 raspberrypi system [1]: homebridge. service: Service RestartSec=3s expired, scheduling restart.
Feb 01 12:12:34 raspberrypi system [1]: homebridge. service: Scheduled restart job restart counter is at 7
Feb 01 12:12:34 raspberrypi system [1]: Stopped Homebridge.
Feb 01 12:12:34 raspberrypi system [1]: Starting Homebridge...
Feb 01 12:12:34 raspberrypi run-parts [7309]: Ensuring /var/homebridge is owned by homebridge
Feb 01 12:12:36 raspberrypi system [1]: Started Homebridge.
