  • Firmwareupdate für EU Aqara Hubs in der Aqara-App
    V 2.8.1_1000.0227
  • Könnte jemand der das Update macht, das Changelog einstellen?
    Ich hab’s verpasst.
    Habe ich das richtig gelesen, dass jetzt auch Deutsch als Sprache möglich sein soll?
  • homebridge-dreambox v0.4.10
    homebridge-switchbot-for-mac v0.2.0
    homebridge-camera-ffmpeg v2.4.1
    Einmal editiert, zuletzt von DJay () aus folgendem Grund: 2 Beiträge von z-smoker mit diesem Beitrag zusammengefügt.
  • [email protected]
    Changelog
    [1.2.1] - 2020-07-26
    Changed
    Fixed dmaker.fan.p5 support
    [1.2.0] - 2020-07-26
    Added
    Added support for the dmaker.fan.1c
    Other new xiaomi fans should also now have initial support
    New miotFan device class which adds initial support for xiaomi miot protocol fans
    New optional deviceId configuration field
    Changed
    Optimized code to easily implement new xiaomi miot fans
    Improved log
    Updated README
    Note: The dmaker.fan.1c does not support moveControl (move left/right) and angleButtons. Since moveControl is automatically enabled this needs to be currently manually disabled in the config.json. Just set moveControl to false if you are using this device.
    Hilfreich? ↆ
  • xiaomi-fan@1.3.0
    Changelog
    [1.3.0] - 2020-07-29
    Added
    You can now configure this plugin to run as a platform
    Added a fan device factory to detect which fan is used
    Added support for the dmaker.fan.p9 fan (Mijia Tower Fan)
    Added support for the dmaker.fan.p10 fan (Mijia 2-in-1 DC Inverter Fan 2)
    Added support for the zhimi.fan.za5 fan (Smartmi Standing Fan 3)
    Added generic miot fan
    Added fan capabilities to easily distinguish what features fan models support
    Changed
    Platform is now also the preferred way to use the plugin, when still using as an accessory a warning will be shown.
    Optimized miot protocol
    Optimized code
    Reorganized project structure
    Updated README
    Note: All users should switch to use the plugin as a platform since the accessory way will be removed soon. In order to switch to platform you just simply need to adjust your config.json as the example in the README.
    Hilfreich? ↆ
  • xiaomi-fan@1.3.1
