homebridge-config-ui-x | Webinterface für Homebridge
Guten Morgen Leute
Heute ist ein neues Update für homebridge-config-ui-x erschienen.
Das ich durch gefürt habe ,nach dem neu start startet meine Homebridge leider nicht mehr
Das wäre die Log Danke
Alles anzeigenOct 24 09:03:50 raspberrypi homebridge[1371]: outerError Error: /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/build/Release/pty.node: wrong ELF class: ELFCLASS64 Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._extensions..node (node:internal/modules/cjs/loader:1340:18) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.load (node:internal/modules/cjs/loader:1119:32) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._load (node:internal/modules/cjs/loader:960:12) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.require (node:internal/modules/cjs/loader:1143:19) Oct 24 09:03:50 raspberrypi homebridge[1371]: at require (node:internal/modules/cjs/helpers:119:18) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js:31:11) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._compile (node:internal/modules/cjs/loader:1256:14) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.load (node:internal/modules/cjs/loader:1119:32) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._load (node:internal/modules/cjs/loader:960:12) { Oct 24 09:03:50 raspberrypi homebridge[1371]: code: 'ERR_DLOPEN_FAILED' Oct 24 09:03:50 raspberrypi homebridge[1371]: } Oct 24 09:03:50 raspberrypi homebridge[1371]: Trying Debug version Oct 24 09:03:50 raspberrypi homebridge[1371]: innerError Error: Cannot find module '../build/Debug/pty.node' Oct 24 09:03:50 raspberrypi homebridge[1371]: Require stack: Oct 24 09:03:50 raspberrypi homebridge[1371]: - /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js Oct 24 09:03:50 raspberrypi homebridge[1371]: - /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/index.js Oct 24 09:03:50 raspberrypi homebridge[1371]: - /usr/local/lib/node_modules/homebridge-config-ui-x/dist/main.js Oct 24 09:03:50 raspberrypi homebridge[1371]: - /usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/fork.js Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._resolveFilename (node:internal/modules/cjs/loader:1077:15) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._load (node:internal/modules/cjs/loader:922:27) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.require (node:internal/modules/cjs/loader:1143:19) Oct 24 09:03:50 raspberrypi homebridge[1371]: at require (node:internal/modules/cjs/helpers:119:18) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Object.<anonymous> (/usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js:38:15) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._compile (node:internal/modules/cjs/loader:1256:14) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.load (node:internal/modules/cjs/loader:1119:32) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module._load (node:internal/modules/cjs/loader:960:12) Oct 24 09:03:50 raspberrypi homebridge[1371]: at Module.require (node:internal/modules/cjs/loader:1143:19) { Oct 24 09:03:50 raspberrypi homebridge[1371]: code: 'MODULE_NOT_FOUND', Oct 24 09:03:50 raspberrypi homebridge[1371]: requireStack: [ Oct 24 09:03:50 raspberrypi homebridge[1371]: '/usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js', Oct 24 09:03:50 raspberrypi homebridge[1371]: '/usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/index.js', Oct 24 09:03:50 raspberrypi homebridge[1371]: '/usr/local/lib/node_modules/homebridge-config-ui-x/dist/main.js', Oct 24 09:03:50 raspberrypi homebridge[1371]: '/usr/local/lib/node_modules/homebridge-config-ui-x/dist/bin/fork.js' Oct 24 09:03:50 raspberrypi homebridge[1371]: ] Oct 24 09:03:50 raspberrypi homebridge[1371]: } Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;31mError: /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/build/Release/pty.node: wrong ELF class: ELFCLASS64#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;31m[node-pty] Node.js v18.18.2#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;31m[node-pty] Failed to load node-pty module#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;31m[node-pty] This could be because the installation of this plugin did not complete successfully or you may have recently upgraded Node.js to a new major version.#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;31m[node-pty] Follow the steps below to resolve this issue.#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;33m[node-pty] Trying to rebuild automatically...#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: #033[0;37m[24.10.2023, 09:03:50] #033[0m#033[0;36m[Homebridge UI]#033[0m #033[0;33m[node-pty] Path: /usr/local/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch#033[0m Oct 24 09:03:50 raspberrypi homebridge[1371]: [24.10.2023, 09:03:50] [SwitchBot] Initializing SwitchBot platform... Oct 24 09:03:50 raspberrypi homebridge[1371]: [24.10.2023, 09:03:50] [CameraUI] Initializing CameraUI platform...
Als bei mir kamen einige Fehler beim Update und am Schluss war das Update scheinbar durchgeführt. Nach dem Neustart der Homebrdge sehe ich die alte Version wieder. Nach einem reboot wird die neue Version angezeigt .
Für so einen Fall (wie deinen) habe ich immer ein Backup parat welches ich regelmäßig automatisch erstelle
Und bei Bedarf zurückspielen kann
Lg Roger
Hi danke für den tip, ich habe aber eine alte Version noch von Honebridge. Da gibt es noch kein hb-Service.
Also bei mir geht gar nichts mehr...
Ich versuche das gerade mit dem rebuild
Werde berichten...
Ist bei mir seit dem Update gestern ebenfalls
Komme nicht mehr auf die Login Seite, rebuild funktionier bei mir nicht,
Es kommt nur noch eine weisse Seite:
Safari kann keine Verbindung zum Server aufbauen
Safari kann die Seite „192.168.178.53:8080/login“ nicht öffnen, da Safari keine Verbindung zum Server „192.168.178.53“ aufbauen kann.
Hat jemand einen Tipp für mich, bin am verzweifeln :((
Bei mir steht folgendes
Homebridge
Starting now...
Homebridge doesn't usually take this long to start.
Something may be wrong, but if you're running a Raspberry Pi 1 or Zero, the initial startup process may take up to 10 minutes, please be patient.
To troubleshoot the problem, please connect via ssh and look at the Homebridge logs.
Aber nach mehr als 10 Minuten passiert nichts
Habe es gerade damit hinbekommen:
sudo npm uninstall -g homebridge-config-ui-x
sudo npm install -g --unsafe-perm homebridge-config-ui-x
Habe ich probiert, aber klappt immer noch nicht bei mir. Irgendwie stürzt mein Pi die ganze zeit seit dem ab
EDIT: Nach mehrmals neu start läft Homebridge wieder. Bekomme aber das in den logs...
Alles anzeigen[24.10.2023, 18:25:39] [Homebridge UI] Error: Cannot find module '../build/Release/pty.node' Require stack: - /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/unixTerminal.js - /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch/lib/index.js - /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js - /usr/lib/node_modules/homebridge-config-ui-x/dist/bin/hb-service.js [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Node.js v18.17.1 [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Failed to load node-pty module [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] This could be because the installation of this plugin did not complete successfully or you may have recently upgraded Node.js to a new major version. [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Follow the steps below to resolve this issue. [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Trying to rebuild automatically... [24.10.2023, 18:25:39] [Homebridge UI] [node-pty] Path: /usr/lib/node_modules/homebridge-config-ui-x/node_modules/@homebridge/node-pty-prebuilt-multiarch [24.10.2023, 18:26:14] [Homebridge UI] [node-pty] Failed to rebuild npm modules automatically. Manual operation is now required. [24.10.2023, 18:26:14] [Homebridge UI] [node-pty] From the terminal run this command to rebuild npm modules: [24.10.2023, 18:26:14] [Homebridge UI] sudo hb-service rebuild [24.10.2023, 18:26:14] [HB Supervisor] ERROR: The user interface threw an unhandled error Error: Node.js global modules rebuild required. See log errors above. at main (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:29754:19) at 1808 (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:29806:1) at __webpack_require__ (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30138:42) at /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30166:1 at /usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30272:3 at Object.<anonymous> (/usr/lib/node_modules/homebridge-config-ui-x/dist/main.js:30277:12) at Module._compile (node:internal/modules/cjs/loader:1256:14) at Module._extensions..js (node:internal/modules/cjs/loader:1310:10) at Module.load (node:internal/modules/cjs/loader:1119:32) at Module._load (node:internal/modules/cjs/loader:960:12)
Hi hat einer das Update 4.51.1 schon probiert?
Ja, läuft.
Ja ohne Probleme aktualisiert
Hi so wieder ein Update da. Kann man des updaten mit node 18 oder wird da jetzt Node 20 gebraucht?
Kann man (eben gemacht), solange man bestimmte Systeme nicht auf node 20 updatet. Steht alles auch in den Release Notes, auch wie man im Fehlerfall wieder zurück kommt.
Homebridge
Starting now...
Hallo in die Runde ...
habe nach einem --unüberlegtem Update das gleiche Problem und stehe gerade total auf dem Schlauch..
Der raspi ist per Ping erreichbar läßt mich aber nicht ..drauf .....
Ich bräuchte bitte nen Tip...
Dankeeeee
Wie würde ein überlegtes Update aussehen?
Lässt dich nicht drauf, wenn du was tust?
Nicht zu Ende gelesen das es zu Fehlern kommen kann
Und wenn ich per ssh oder putty versuche den raspi zu erreichen ....
habe mich ewig nicht mehr damit beschäftigt
Wenn du dich mal einfach umdrehst und deinen Blick durch die Umgebung schweifen lässt, wird dir möglicherweise auffallen, dass ich nicht hinter dir stehe und dir dabei zusehe, was du machst. Daher verzeihe mir bitte die saublöden Fragen wie:
Was passiert genau, wenn du versuchst den Raspi per ssh oder PuTTY zu erreichen? Bezeichnen "ssh oder putty" zwei Versuche mit unterschiedlichen Technologien und beide gehen nicht? Gibt es Fehlermeldungen, die der Erwähnung wert wären (was auf alle Fehlermeldungen zutrifft)?
Sorry jetzt widme ich dem mal mit 100%...
putty ... pi@....... port 22 ist angegeben
dann möchte er ein Paßwort...ich glaube ich habe es nicht geändert--Standartpw- aber er sagt kein Zugriff
