  • homebridge-config-ui-x
    Release Notes
    4.29.0 (2020-10-13)
    Notable Changes
    • Plugins: Added the ability to rollback to a previous version of a plugin, or install the beta/test version of a plugin
    • Homebridge: Added the ability to rollback to a previous version of Homebridge, or install the latest beta version of Homebridge (#877)
      • Click the Homebridge version on the status dashboard to access this feature
    • Config Editor: Automatic backups of the config.json file are now saved to ./backups/config-backups/ to reduce clutter in the Homebridge storage folder (#732)
      • Existing config backup files will be moved on next restart
    • Restart: Made it more obvious which button to click when you need to restart Homebridge
    • Restart: The restart page now shows separate statues for the UI and Homebridge
    • Restart: Users running with hb-service will now be prompted to view the Homebridge logs if the Homebridge service is taking a long time to come back online after a restart
    • i18n: Brazillian Portuguese (pt-BR) language added by @zearthur99 (#880)
      • The Homebridge UI is now available in 21 different languages!
    Other Changes
    • Plugins: Minor cosmetic improvements to the plugins settings GUI
    • i18n: Improvements to French language translations (#881,#882)
    • i18n: Improvements to Polish language translations (#884,#886)
  • [email protected]
    [2.0.6] - 2020-10-13
    Fixed
    • Fixed an issue where the channel buttons service would not update the status in some cases
    • Setup on tv connection should not get stuck now in cases where no response comes back from the tv
    Changed
    • Some under the hood improvements
    • Updated README
    Hilfreich? ↆ
  • watchOS 7.0.2 ist schon zwei Tage raus und niemand sagt was...
  • deconz-rest-plugin - Pre-release V2_05_85 - Hydaspes
    Hydaspes
    Repository: dresden-elektronik/deconz-rest-plugin · Tag: V2_05_85 · Commit: 0608e15 · Released by: manup
    Phoscon App
    • New translation system, currently French, German and English translations are availble. More coming soon.
    • Default device search time raised from 1 to 3 minutes.
    • Motion sensor control allows presence, opnen/close, vibration and water sensors as triggers.
    • Support Lightify Mini Switch in Switch Editor.
    • More sensors are shown under Devices → Sensors.
    Device support
    • Support Tuya TS0041, TS0042, TS0043 switches #3398
    • Support Zemismart chain roller shades driver M515EGB (TS0601) #3398
    • Support Tuya / Wesmartify thermostat Essentials Premium #3398
    • Support Samjin motion sensor #3408
    • Support Add button maps for ZGRC-KEY-007 and ZGRC-KEY-009 #3408
    • Support BOSCH motion sensor ISW-ZPR1-WP13 #3408
    • Support Ilumra Friends of Hue switch #3285
    • Initial support for Elko ESH 316 Endevender RF #3409
    • Fix creating unwanted lights for Xiaomi vibration sensors #3364
    Under the hood
    • Support ZGP (Friend of Hue) switches to route through the mesh network #3418
    • Allow disable permition auto off sending #3416
    • Show battery icons in deCONZ GUI based on battery state #3421
  • deconz beta 2.05.85
    homebridge-camera-ui v3.0.1
    • Completely redesigned and refactored UI
    • Multi-language support
    • Full functional webapp
    • WebApp Push notifications
    • Supports multiple accounts/roles
    • Drag and Drop and Resizable Cams (CamViews)
    • Almost everything is adjustable
    • Webhook support
    • Telegram support
    • Recordings (Snapshot/Video) Support
    • New Cameras Dashboard
    • Latest notifications
    • Camera-FFmpeg under the hood
    • Possiblity to change between livestream and snapshots
    • Rooms
    • Darkmode
    • Themes
    • ..and much more!
  • homebridge-camera-ui
    v3.0.5 - 2020-10-18
    • Added new function that allows to see missed notifications after login
    • Fixed Translation & added new translation
    • Fixed an error with ServiceWorker for Firefox
    • Prevent creating a user with same name as admin (Master)
    • Fixed a bug with Webhook that caused the "Trigger" and "False" commands to be triggered incorrectly
    • UI Improvements
    v3.0.4 - 2020-10-17
    • Added more translation
    • Fixed a bug that caused the preloader not to be hidden on an "Error" page
    • Fixed a bug where camera pages containing a spaces were not displayed
    v3.0.3 - 2020-10-17
    • "Reset" will now automatically set itself to "false" in config.json after resetting master credentials
    • After opening the app or visiting the main page ("/") the last opened page is now opened if the user is logged in (fixed)
    • 404 will now work properly
    • More debug
    • Bugfixes
    • UI improvements
    v3.0.2 - 2020-10-16
    • Fix unauthorized error
    • Fix UI if auth = none
    • UI Improvements if camera socketPort/source is not setted up
  • Deconz v2.5.86 beta version.
    Changes
    • Fix setting temperature mode and child lock for Elko Super TR thermostat #3433
    • Use reporting instead polling for Elko Super TR, Owon AC201, Stelpro Orleans Fan SORB, Centralite pearl 3157100, Bitron 902010/32 #3433
    • Fix crash while polling lights #3445
    • Fix Ilumra FoH dual rocker switch detection #3439
    • Fix button handling for lumi.sensor_86sw switches #3431
    • Fix Aqara Opple switches button release events (x0003) and Ikea wireless dimmer #3428
    • Disable reporting of firmware version for IKEA lights #3446
    • Fix ZCL attribute set listings in deCONZ GUI Cluster Info Panel
    A special thanks to all contributors of the deCONZ Github community.
  • Hydaspes Hotfix #1
    This is a hotfix release for the v2.5.86 beta version.
    Changes
  • Homebridge Shelly
    homebridge-shelly v0.15.7
  • iOS 14.1
    iPadOS 14.1
    HomepodOS 14.1
  • [email protected] (2020-10-21)
    Notable Changes
    • i18n: Catalan (ca) language added by @bwp91 (#892)
    • Themes: Added 11 more dark mode theme options with various colour accents (#883)
    • The Homebridge UI is now available in 22 different languages!
    Bug Fixes
    • System: Initial support for Node.js v15 and npm v7, however please stay on the current LTS version of Node.js (currently v12.19.0) (#904)
    • Config Editor: Fixed a bug that prevented the purging of config.json backups (#898)
    • Ring Plugin: Fixed an issue that prevented two factor authentication codes with leading zeros from being accepted when linking a Ring Account (#dgreif/ring#471)
    Other Changes
    • Config Editor: Updated the config editor hover help text to let users know it's possible to define an interface or an IP for the mdns interface (#899)
    • i18n: Improvements to Slovenian language translations (#889)
    • i18n: Improvements to Simplified Chinese language translations (#890)
    • i18n: Improvements to Spanish language translations (#891,#900)
    • i18n: Improvements to French language translations (#893)
    • i18n: Improvements to Italian language translations (#894)
    • i18n: Improvements to German language translations (#895)
    • i18n: Improvements to Japanese language translations (#897)
    Hilfreich? ↆ
  • [email protected]
    Changelog
    Fixed
    • CleaningRobot/CoffeeMaker/CookProcessor/Dishwasher/Dryer/Hob/Oven/Washer/WasherDryer: Imply from a change to Operation State Inactive that the appliance Power State is Standby, even if no event has been been received. (#35)
    • CleaningRobot/CoffeeMaker/CookProcessor/Dishwasher/Dryer/Hob/Oven/Washer/WasherDryer: Do not warn when the appliance does not have a program selected.
    [email protected]
    Release Notesv2.0.0
    ⚠️ Updating from v1There are some differences in configuration from v1. You are likely to be affected if you:
    • Disable device discovery
    • Use a Wemo Maker in GarageDoor mode (as opposed to Switch mode)
    Please see this issue for more info about the config changes and what you'll need to do.Changes from v1Feature-wise, not much at all. The idea of this release was a restructure of the code to make it easier to implement new features in the future. So if you have any ideas then do let me know already!Problems/IssuesIf you experience any issues with this release, please let me know as soon as possible so I can look into a fix. If you need an immediate rollback to v1, you can use this command in your Homebridge terminal:
    sudo npm i -g [email protected]
    Hilfreich? ↆ
  • homebridge-nest v4.4.14
    Release Notes
    Fix for fan timer duration characteristic warning in Homebridge 1.3.0.
    homebridge-platform-wemo v2.1.0
    Release Notes
    • New disableDeviceLogging config option if you don't want device updates to be added to the Homebridge log
    • Fix for Wemo Link brightness if controlled by the Wemo app (#210)
    • Fix for Wemo Insight On/OutletInUse characteristics (#208)
    • Improved error logging for all devices (HB will no longer crash if e.g. if device in unreachable)
    Hilfreich? ↆ
  • Release Notes
    homebridge-config-ui-x v4.31.0 4.31.0 (2020-10-28)
    Notable Changes
    • Backup/Restore: Full instance backups are now automatically made daily (01:15) (#660)
      • Backup archives will be kept for 7 days before being removed
      • Backup archives will stored in your Homebridge config folder (./backups/instance-backups)
      • Users can customise the directory that backups are saved to by setting the scheduledBackupPath option - this allows you to have the automated backups archives saved to a network share or backup drive
      • Users can download these scheduled backups by opening the existing Backup / Restore tool
      • Added REST API endpoints for getting the list of automated backups, and downloading an existing backup archive
      • See the Homebridge Backup and Restore wiki article for further information about instance backups
    • hb-service: Added full support for Enterprise / Red Hat / CentOS / Fedora Linux distributions - wiki guide here
    Other Changes
    • Config Editor: When loading a previous version of the config.json, a diff will be shown to highlight the changes from the current config and the one that will be restored (#910)
    • Config Editor: Previous versions of the config.json file more than 60 days old will be periodically be deleted to remove the need for manual maintenance (#732)
    • User Accounts: You can now change the login username of existing user accounts
    • i18n: Improvements to French language translations (#916)
    • i18n: Improvements to Spanish language translations (#917)
    • i18n: Improvements to Polish language translations (#918)
  • Firmware-Update: Der Eve Light Strip kann jetzt adaptives Licht!
    https://www.evehome.com/de/blo…p978gcLzHCNaIMyd9L5Xynunc
