iOS 13.3.1 ist raus
Endlich 😊
HomePod 13.3.1 ist auch verfügbar
watchOS 6.1.2 ist ebenfalls verfügbar
Bei wurde die Kaffeemaschine mit 0.16.5 ständig als offline angezeigt, obwohl mit WLAN und auch HomeConnect Server verbunden. https://github.com/thoukydides…dge-homeconnect/issues/15
Direkt nach dem Update auf 0.16.6 und Neustart der Homebridge, funktionierte es ohne weiteres Zutun direkt wieder einwandfrei.
Notable Changes
New feature (#2): After a reboot of Homebridge, a stateless switch checks if there is a remaining delay-time and stays on for this timespan. This is specifically useful for stateless switches with high delay values.
Bug fix: After a reboot of Homebrdige the CLI commands specified at 'onCmd' or 'offCmd' have been erroneously executed. This is now fixed.
Notable Changes
Plugins: Added a confirmation box when uninstalling plugins
Plugins: Added an option to have a plugin's config removed from the config.json when the plugin is being uninstalled (only plugins that implement the Plugins Settings GUI support this feature)
System: The UI will now attempt to rebuild it's own modules after a Node.js upgrade
System: Added the ability for hb-service users to clear the Homebridge cached accessories from the UI (without doing a full Homebridge reset)
Dashboard: Weather widget now supports local translations of the current weather description (#515)
Other Changes
i18n: Improvements to Polish language translations (#519)
hb-service: Adjusted the hb-service rebuild command to just rebuild the modules used by Homebridge Config UI X. This command should now work to fix the modules used by Homebridge Config UI X on any setup - not just those using hb-service as a process supervisor
Accessory Control: Minor tweaks to the Speaker accessory type
Updated npm dependencies
Entweder ich bin blind oder suche an der falschen Stelle, wie installiere ich das Update korrekt?
In deinem Browser
Changed
Avoid issuing API requests to read or change settings where they would result in errors. In particular, settings (such as power on/off) are now only changed when remote control is enabled and local control is not active. For Hood appliances the details of the functional and ambient light settings are only read after confirming that those settings are supported.
Suppress the error that is returned when no programs are available due to an appliance's state.
Enable timeouts for all Home Connect API requests. This ensures that event stream failures are detected reliably.
oder über ssh auf dem Raspi ... über das WebInterface hat es bei mir auch erst nicht geklappt.
Wer npm-check installiert hat, auch über: npm-check -gu, anschließend config-ui-x auswählen und ENTER.
Danke für die Rückmeldungen.
Als Rookie habe ich immer Angst mir etwas zu verhauen.
Node.js 12.15.0 LTS
Ratet ihr Nods zu aktualisieren wenn das System läuft?
bin noch bei 11.16 oder so
