Deconz-2.05.74-qt5.deb
Pihole 4.4
homebridge-xiaomi-roborock-vacuum 0.7.0
mit
NEW Feature: Room cleaning with separately switch for each room
Schon jemand ausprobiert?
[email protected] (2020-02-27)
Release Notes
Do you like Homebridge Config UI X? Star us on GitHub!
Backup / Restore Feature
This release comes with a new feature that allows users to backup and restore their entire Homebridge instance.
The backup and restore process works in such a way that users should be able to use the feature roll back to a previous state, or transfer their current Homebridge setup to a new server without the need to re-pair with HomeKit.
Highlights:
- Full backup of your Homebridge storage, persist and accessories folders
- Migrate your Homebridge instance to a new platform or server with ease
- Rollback your existing instance in seconds (if you made a full backup first)
- The backup is a standard .tar.gz archive (this means manual restores or extracting a single file is possible)
- Works on all platforms that are supported by Homebridge Config UI X including Docker, macOS, Windows 10, Linux and Raspbian
- The restore process will install any missing plugins (provided they are published to npm)
Notable Changes
hb-service: When running under Homebridge using the
hb-serviceprocess supervisor, the following changes have been made to the Restart action from the UI:- If no changes have been made to the Homebridge Config UI X, or the
bridgesections in theconfig.json, just the Homebridge process will be restarted - If changes have been made to either of those sections, both the UI and the Homebridge processes will be restarted as per normal
- This change will significantly decrease the Homebridge restart time on lower powered devices
- No changes have been made to the
hb-service restartcommand executed via the Terminal
Other Changes
Neues in [email protected]:
Die Bridge-Config in config.json wurde erweitert durch zwei neue Bezeichner: manufacturer und model, so dass sie nun so aussieht:
"bridge": {
"name": "Homebridge",
"manufacturer": "homebridge.io",
"model": "homebridge",
"port": 51826,
"pin": "031-45-154"
Diese Zeilen können in die config.json eingefügt werden, müssen es aber nicht. Die Werte können natürlich auch verändert werden, also beispielsweise in:
"manufacturer": "Ich nicht",
"model": "Wohnzimmer-Bridge",
Sonst gibt's nichts weiter Erwähnenswertes.
Die Zeilen gibt es doch schon länger, habe diese schon ewig in der Config
So? Ist ja der Hammer
Added
- Support for config-ui-x
- Custom tresholds for apple home sensors
- Unit sitorr for air pressure in mmhg
[email protected]
Notable Changes
hb-service: Added the ability to toggle Homebridge insecure mode (
-I) from the UI when running underhb-service - Accessory Control: Added support for Security System accessory types (#47)
- Accessory Control: Added support for Leak Sensor accessory types (#47)
- Dashboard: Added a configurable option to each widget to determine if it should be shown in the mobile/compact view (#560)
- Dashboard: @Staubgeborener added an option to the Homebridge status widget to let users decide if the Homebridge port should be shown or not (#572)
Zitatadd support for Node 12
deconz 2.05.75
Added contact sensor for cloud service connection tracking
- Creates a Contact Sensor that monitors the status of the connect to the Homebridge Alexa Cloud Servers.
[email protected]
4.4.2
- Fix bug when using scenes to adjust thermostat.
- Fix 'Lock Lock' naming issue for Nest x Yale Locks.
- Other bug fixes and reliability improvements.
4.4.4
- Code refactor to use ES6 classes.
- Added Promise.prototype.finally polyfill to support older NodeJS versions.
- Small bug fixes.
0.2.17/0.2.18
Enhancements:
- Default to
Musicscript on macOS >= 10.15, see #17. - Rename
AirfoilandEyeTVscripts toiTunes-AirFoilandEyeTV-Airfoil. - Log macOS version on startup.
Bug fixes:
- Suppress invalid JSON error when no result received from AppleScript.
- The value of script in config.json was overwritten with Music, see #19.
Bump dependencies:
- Support homebridge v0.4.52;
- homebridge-lib v4.5.5.
