homebridge-switchbot-openapi@3.0.0 (2021-02-12)
- Added
pushRateto set the amount of time inbetween pushes to API. - Housekeeping and Update Dependencies.
- Works on Curtains and Humidifers Devices.
- If set higher, changes take longer, prevents excessive pushes to API.
Version 2.4.0 (2021-02-09)Changes
- Added options to hide temperature sensor or humidity sensor on SwitchBot Meter.
- Added options to convert temperature to Celsius or Fahrenheit of SwitchBot Meter.
- Removed LockPhysicalControls Characteristic since there is not a way to control it with the SwitchBot API.
Version 2.3.0 (2021-02-08)Changes
- Added option to display bot as a switch instead of an outlet.
In eigener Sache: Bei Bestellungen im SwitchBot Shop, Rabattcode SMARTAPFEL10OFF nicht vergessen.
