homebridge-hue v0.12.20
homebridge-casambi v0.3.3
homebridge-config-ui-x_4.37.0 (2021-01-30)
Notable Changes
i18n: Macedonian (mk) language added by @dimovskidamjan (#1011)
- The Homebridge UI is now available in 24 different languages!
Plugins: The following features have been added to assist plugin developers building custom plugin user interfaces:
- Added an option to retrive a list of cached accessories for the plugin using the
homebridge.getCachedAccessoriesmethod
Other Changes
- i18n: Improvements to Portuguese language translations (#1014,#1034,#1038)
- i18n: Improvements to Polish language translations (#1032,#1036)
- i18n: Improvements to French language translations (#1035,#1037)
- i18n: Improvements to Catalan language translations (#1042)
- i18n: Improvements to Spanish language translations (#1039)
- i18n: Improvements to Turkish language translations (#1041)
- i18n: Improvements to Traditional Chinese language translations (#1045)
Bug Fixes
- Dashboard: The battery accessory type is now correctly displayed in the Accessories widget (#998)
Homebridge v1.3.0 Features
[email protected] (2021-01-30)
Notable Changes
- New configuration option
modeto choose between: -
discoveryIntervalnow needs a minimum value of15and discovery cannot be disabled
mode: "auto"the plugin will auto-discover devices and configure manual devices (default if option not set) -
mode: "manual"the plugin will only configure manual devices
- Existing configurations with lower value will be disregarded and
15will be used - The option of disabling the discovery interval has been removed as this interval is essential for correcting connection issues for all your Wemo devices
New
- Support for the Wemo Outdoor Plug
- [Experimental] Automatic port scan for manual devices
- Set a custom
noMotionTimerper Wemo motion device (NetCam/Motion Sensor) - Cumulative
TotalConsumptionfor Insight devices - Set a custom
wattDiff(wattage difference) for Insight devices - the plugin will not log consecutive wattage updates if the difference from the previous is less than this value (default:0)
- Use a full address
http://192.168.1.X:49153/setup.xmlas before to fully configure a manual device - Use an IP
192.168.1.Xto let the plugin scan between ports 49152 - 49155 and choose the correct port
- If this is not configured then the plugin will continue to use the global
noMotionTimersetting per motion device - If the global setting is not configured then the plugin will use the default of 60 seconds
- This changes the current method of resetting each day
- This can be reverted back to resetting each day in the plugin settings with the
showTodayTCconfig option
Changes
- Logging for manual devices that cause errors when loading (e.g. IP/port change)
- Fixes an issue where the Insight would consistently log outlet-in-use between true and false
- More consistent and clearer error logging
- Updated plugin-ui-utils dep and use new method to get cached accessories
macOS 11.2 ist draußen
[email protected] (2021-02-01)
Changes
- Configuration Changes
- Clean up the plugin-ui by removing unnecessary descriptions
- Fixes a bug when initialising Garage Doors
- These changes are backwards compatible with existing setups
- New 'Wemo Outlets' section to define outlets to show as switches
- Removal of
removeByNamefrom the UI, this setting is still available manually - Deprecation of the following settings:
- These deprecated settings have their own section in the plugin UI
disableDiscovery- now has no effect -
doorOpenTimer- now configured per Wemo Maker device in the 'Wemo Makers' section -
noMotionTimer- now configured per Wemo Motion device in the 'Wemo Motions' section -
outletAsSwitch- now configured per Wemo Outlet device in the 'Wemo Outlets' section
iOS 14.5 Beta
WatchOS 7.4 Beta
Wichtigste Neuerung: Beim Tragen einer Maske wird das iPhone nun ENDLICH via AppleWatch entsperrt. Das funktioniert tadellos. Beide Geräte müssen mit der Beta versorgt sein und das erste Entsperren funktioniert nur per Code. Dann gehts aber recht gut muss ich sagen.
Nen Jahr bis zu dieser Funktion ist schon krass, aber egal.
Hat jemand einen Link zum changelog?
Hat jemand schon geupdatet? Ist ja ein ganz schöner Versionssprung.
Eigentlich nicht. Ändert sich die erste Zahl, würde ich mir Gedanken machen. Update lief bei mir jedenfalls problemlos durch.
Alles anzeigenv7.5.2 (2021-02-02) BUG FIXES 37613e4e6 #2395 #2329 fix(exec): use latest version when possible (@wraithgar) 567c9bd03 fix(lib/npm): do not clobber config.execPath (@wraithgar) DEPENDENCIES 643709706 @npmcli/[email protected] (@isaacs) 4c6be4a Restore npm v6 behavior with INIT_CWD bbebc66 Do not set the PREFIX environment variable v7.5.1 (2021-02-01 BUG FIXES 0ea134e41 #2587 pass all settings through to pacote.packument, fixes #2060 (@nlf) 8c5ca2f51 Add test for npm-usage.js, and fix 'npm --long' output (@isaacs) DEPENDENCIES 7e4e88e93 @npmcli/[email protected], [email protected] Properly raise ERESOLVE errors on root dev dependencies Ignore ERESOLVE errors when performing git dep 'prepare' scripts Always reinstall packages that are explicitly requested fix global update all so it actually updates things Install bins properly when global root is a link (@isaacs) DOCUMENTATION 23dac2fef #2557 npm team revamp (@ruyadorno) dd05ba0c0 #2572 add note about --force overriding peer dependencies (@isaacs) e27639780 #2584 Fixed the spelling of contributor as it was written as conributor (@pavanbellamkonda) 13a5e3178 #2502 elaborate that npm help uses browser (@ariccio)Roborock S6 Firmware 3.5.8_5690
- Erkennung von Objekten und Hindernissen wurde optimiert
- Bugfixing
[email protected] (2021-02-06)
Other Changes
- i18n: Improvements to Polish language translations (#1047,#1049,#1058)
- i18n: Improvements to Spanish language translations (#1055)
- Homebridge: The dashboard will now show when a newer beta release is available (only for users currently running a beta version of Homebridge)
Bug Fixes
- Fixed an issue that would prevent the UI from rendering in some older browsers when it was accessed via an IP address
Homebridge v1.3.0 FeaturesThese features will appear in once Homebridge v1.3.0 or later is installed (currently in beta)
- Plugins: Added the ability to configure, manage, and restart child bridges
Dashboard: Added a new Child Bridge Status widget the dashboard for
hb-serviceusers that shows the current status of a child bridge (down, pending, ready) and allows you to restart an individual child bridge
- Child bridges allow you to run any plugin's platform or accessory as an isolated child bridge without having to manage multiple Homebridge instances
Nanoleaf Essentials Firmware Update bringt Adaptive Lighting!
1.4.29 (2021-02-08)
• Added support for Color Scenes
• Added support for Apple Adaptive Lighting
• Minor bug fixes and improvements
Das Dockerfile von oznu-Homebridge wurde auf die Node.js Version v14.15.5 aktualisiert.
Eve App 5.0.2
Und damit u.a. endlich Temperatur Anzeige vom Hue Motion Sensor in der Übersicht.
Tedee Lock Firmware
Update für
das Schloss v 1.1.47818
die Bridge v 1.0.47819
Auszuführen jeweils über die App.
deConz Beta 2.09.02
in kürze Beta 2.09.03
Deconz Release v 2.9.3
Roanoke
Repository: dresden-elektronik/deconz-rest-plugin · Tag: v2.9.3 · Commit: 9408372 · Released by: manup
This stable release is the successor of v2.7.1 and includes all changes from:
Please refer to the releases page to get and overview of respective changes.
This release has 2 assets:
- Source code (zip)
- Source code (tar.gz)
Visit the release page to download them.
