Eve Thermo 4. Gen. Leider noch nicht das Thread Update...
homebridge-hue
Release Notes
v0.13.0
Changes
- Minor version bump: Make sure to update to Homebridge v1.3.3 before updating Homebridge Hue;
- Refactored the parsing of
config.json(in preparation for move to dynamic platform accessory plugin). The parser is now strict on capitalisation of the keys. Use the Homebridge UI and/or see the Wiki for the correct spelling. Alsohosthas been removed in favour ofhosts, which now must be an array of string values. - Use standard definitions for adaptive light characteristics, available in Homebridge 1.3.3;
- Use standard definition for
Current Temperaturecharacteristic, which has a minimum value of -270 in Homebridge 1.3.3.
Enhancements
- Add support for Hue wall switch module, see https://github.com/dresden-ele…z-rest-plugin/issues/4566;
- Add support for Linkind 1-Key Remote Control, see #949.
Bug Fixes
- No checkbox for
stealthconfig.json setting in the Homebridge UI.
Bump Dependencies
- Homebridge v1.3.3;
- homebridge-lib v5.1.0;
- ws v7.4.4.
Achtung: homebridge-hue 0.13.0 macht Ärger.
v0.13.1 ist online und macht keine Ärger mehr
v0.13.1 macht bei mir noch massiven Ärger!!
Wette es liegt am „host“/„hosts“ string/array im config
betaV0.13.2 ist raus - war irgendein Problem mir dem autodetecting der Bridges.Ich trau mich nicht!Habe mich getraut! Läuft!!
[email protected] (2021-03-14)
Added
- Device's current state will be requested immediately when initialised into Homebridge
- Optional polling setting for newer Wemo Dimmers that don't automatically notify the plugin when the brightness is changed externally
- Optional 'timeout' setting for Wemo Insight to configure a minimum time between wattage log entries
Changes
- Open/close time setting for Wemo Makers will be hidden if device is set to expose as switch
- Wemo Makers no longer need 'dummy' contact sensor to view Eve history
- Adaptive Lighting now requires Homebridge 1.3 release
- Wemo Crockpot polling interval will be stopped if Homebridge shuts down
- For this reason, the
exposeContactSensorsetting is now redundant and so has been removed
deCONZ 2.10.3-beta
homebridge-camera-ui
v3.3.0 - 2021-03-21
NEW: Image Rekognition
- Added Image Rekognition with Amazon Web Services to analyse, detect, remember and recognize objects, scenes, and faces in images. You can enable for each camera the image rekogniton and you can even set labels for each cam. For each object, scene, and concept the API returns one or more labels. Each label provides the object name. For example, suppose the input image has a lighthouse, the sea, and a rock. The response includes all three labels, one for each object.
NEW: Telegram Notification
- Now it is possible that the image is sent immediately via Telegram without saving the image/video before. (Recording must be active under setting and Telegram must be set to 'Snapshot' for the camera).
NEW: Filter Function
- Discover the completely redesigned filter function of camera.ui. It is now possible to filter by camera, room, type and even time.
NEW: Endpoints
- Added "exclude" as a new endpoint to trigger via webhook
- Added "getSettings" as a new endpoint to get current ui settings
- Refactored config.schema.json
- Refactored MQTT/HTTP and automation handler
- Added TLS option to MQTT
- Added timeout to ffmpeg streams
- Added notification payload to webhook
- Fixed incorrect ffmpeg stream sessions
- Fixed motion handling
- UI design improvements
- General improvements & bugfixes
- Added more debug
- Bump deps
Demo: https://www.reddit.com/r/homeb…/v330_homebridgecameraui/
Github: https://github.com/SeydX/homebridge-camera-ui
SeydX
homebridge-tado-platform
v6.0.9 - 2021-03-22
- Added "Dummy Switch" option to Central Switch
- Added new accessory type option (LightSensor) to Solar Intensity Accessory
- Added new mode (CUSTOM) to HOT_WATER devices
- Fixed current state of HeaterCooler if temperature is reached
- Fixed AUTO mode for HOT_WATER devices
- Bugfixes
- Bump deps
[email protected] - 2021-03-22
- Trigger HomeKit automations when pressing Volume Up/Down on the remote control
[2.1.1] - 2021-02-27Fixed
- Fix screen on/off feature on newer LG TVs.
homebridge-config-ui-x× Release Notes4.41.0 (2021-03-22)Notable ChangesOther Changes
- Dashboard: The Homebridge status shown on the dashboard will now instantly reflect the current Homebridge status
- As additional status of Starting has been added, which is shown when the Homebridge process has been spawned, but not yet fully loaded
- These changes will only be enabled when combined with
hb-serviceand Homebridge v1.3.3 or later
- i18n: Thai (th) language added by @tomzt (#1114)
- i18n: Improvements to Slovenian language translations (#1116)
- i18n: Improvements to Indonesian language translations (#1117)
- i18n: Improvements to French language translations (#1121)
- i18n: Improvements to Spanish language translations (#1122)
- i18n: Improvements to Portuguese language translations (#1124)
- i18n: Improvements to Polish language translations (#1125)
- i18n: Improvements to German language translations (#1127)
- i18n: Improvements to English language translations (#1130)
- i18n: Improvements to Traditional Chinese language translations (#1133)
- i18n: Improvements to Simplified Chinese language translations (#1135)
- The Homebridge UI is now available in 25 different languages!
Meine Netatmo Station (V3) hat heute ein Firmwareupdate gemacht.
Bei mir ist es jetzt die 181.
stable deconz-2.10.04-qt5.de
beta deconz-2.10.04-qt5.de
Gut wäre es wenn man die Betriebssystemversion dazu schreiben würde. Für Windows z.B. sind andere Versionen aktuell
Windows Deconz 2.10.03 vom 16.3.2021
